lift question!
Discussion in 'Suspension' started by t.hornstra, Jan 21, 2009.
  1. Jan 21, 2009 at 10:27 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    so my lift came in the mail today, its the 2.5front 1.5 rear rough country lift
    can someone explain how the spacer is only 1.5 inches max.. and how it lifts the front 2.5?!
    i want to be familiar with my truck : ] ive only worked on my 66 mustang, and they are quite different.
    also what are the biggest tires i could run? i was hoping to get 285/75R16
    would these fit on a stock rim with the lift?
    its a 2002 Tacoma Prerunner
    thanks!
  2. Jan 22, 2009 at 3:03 PM
    1 bad tacoma
    1 bad tacoma Well-Known Member
    rustburg Va
    05 trdsport 4x4
    grapics, 6" fabtech lift, volant intake with ram air scoop, cleared head lights, chrome kit, westin bull bar and steps, custom toyota emblem, throttle body spacer, flomaster 40 series, dick cepeck black and sliver dc1s, trd seat covers, thrid brake light cover, chrome tail lights
    "can someone explain how the spacer is only 1.5 inches max.. and how it lifts the front 2.5?!
    i want to be familiar with my truck" i compress your springs with in turns lifts the front if i'm not mistaken
  3. Jan 22, 2009 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Being as the shock/spring assembly is 1/2 way between the "A" arm pivot point, and the spindle, a 1.5" spacer will yeild a 3" lift. In the rear, the axel is solid, so a 1" lift via block or spring, will give 1" lift.
  4. Jan 22, 2009 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A 285/75/16 on the stock wheels will rub the bejeezus out of the Upper Control Arm. Best bet is getting replacement Upper Control Arms, Different wheels with a different off set, or a wheel spacer.
  5. Jan 23, 2009 at 10:43 AM
    1 bad tacoma
    rustburg Va
    05 trdsport 4x4
    yea i found that out the hard way when i had my leveling kit i finally got rid of that and went to 3 inch toytec with my rims a 4.5 inch backspacing
