lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devanb3, Apr 16, 2014.
  1. Apr 16, 2014 at 8:49 AM
    devanb3
    devanb3 [OP] Well-Known Member
    devan
    hampstead
    ive looked around for this and havent found anything but i was wondering if anyone had done a 3 in suspension lift with a 3 in block lift?? and if this was a bad idea or doable... im looking at the toytec 3 in suspension with the ready lift block set... im not doing any hard off roading but still doing some plus wanted to know what the biggest tires i could fit with such a lift would be
  2. Apr 16, 2014 at 10:41 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Leave the block, and spacer kits alone. The front suspension will bottom out BEFORE hitting the bump stops. This will eventually lead to catastrophic strut failure. (Per Billstien's website). Save your money and get a quality lift!
    Keep in mind: Larger tires might require regearing your rearend.
  3. Apr 16, 2014 at 12:13 PM
    devanb3
    devan
    hampstead
    didnt think of that would it be better to try to build a kit or buy a presetup kit and what all pieces do i need if i buy in pieces
