Lift question
Discussion in 'Suspension' started by eric.gumberry, Jul 12, 2015.
  1. Jul 12, 2015 at 5:32 AM
    eric.gumberry
    eric.gumberry [OP] Well-Known Member
    Eric
    North Carolina
    2006 6 speed 4x4
    17 in methoods and 265/70r17, 884s and billys at 1.75 in front no rear lift
    Being only 16 i don't know much about lifting my truck I have read all over and I think its between the 5100s and ome885, the 9000 with 885, or the ome kit for toytec...the 5100s would be cheaper but I want my truck to ride halfway good at least the same as stock...I do carry a flour wheeler around quite offer so it would have to be able to handle that without so much squat
  2. Jul 12, 2015 at 4:22 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    How much do you want it lifted?? I would not go with only 5100s unless you keep them on the 1.75" setting.
  3. Jul 12, 2015 at 4:32 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    I was looking for a 3 inch so I could run 285/75/16 and without out uca ...but would probably end up buying them
  4. Jul 12, 2015 at 5:01 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    At 3" and above, you will definitely need UCAs if you want it to drive good, unless it's a drop bracket lift. I'd go with 5100s and OME 887s. The whole set up, with LR UCAs will be around $1100.
  5. Jul 12, 2015 at 7:30 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    So that will give me like 3.5 ? And will I need 2 in aal
  6. Jul 12, 2015 at 7:30 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
