lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by streetcustoms, Jun 28, 2009.
  1. Jun 28, 2009 at 8:59 PM
    streetcustoms
    streetcustoms [OP] Well-Known Member
    tujunga , ca
    prerunner sr5 trd off road
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74196-my-build-so-far.html
    i have ome 885 coils with ome shocks and rear i have aal with shock extenders if i were to do a 3 inch rear lift wit fox shoxs would i have to put bigger coil spacers in the front
  2. Jun 28, 2009 at 9:01 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    What do you mean by 3" lift in the rear??
    Don't you already have a 3" lift?
  3. Jun 28, 2009 at 9:51 PM
    streetcustoms
    tujunga , ca
    no i have a 1.5 inch aal if i were to get the all pro off road 3inch leaf pack lift
  4. Jun 28, 2009 at 10:07 PM
    toku58
    Mall Crawler!
    I'm not sure if the All Pro springs actually give you a true 3" lift in the rear?
    But as for the front? I assume you already have the top plate spacer?
    You cannot go much more on lift for the front. 3" lift for the front is the Maximum you should go on the front stock suspension.
    If you want more lift you need to do a DB set up or spindles depending if your truck is a 2WD or a 4WD?
  5. Jun 28, 2009 at 10:19 PM
    streetcustoms
    tujunga , ca
    its a 09 dc trd off road i wanna get a 4 inch lift i have ome shocks and 885 coils in the front with the spacer it came with can i put a bigger spacer
  6. Jun 28, 2009 at 11:17 PM
    toku58
    Mall Crawler!
    What is it? 4WD or 2WD?
  7. Jun 29, 2009 at 12:32 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    His details state 2WD
  8. Jun 29, 2009 at 12:49 AM
    toku58
    Mall Crawler!
    Ah? O.K. (Spaced on that one:D)
    Well my advice to you would be to look into Camburg or TC spindles. Or maybe a basic ProComp lift?
    4" of lift on the stock components is too much IMHO.
    You can do it. But expect to have some problems down the road.
