Lift question
Discussion in '5 Lug' started by Steven07, Feb 12, 2017.
  1. Feb 12, 2017 at 8:15 AM
    Steven07
    Steven07 [OP] Well-Known Member
    Steven
    2017 Gray SR5 Tacoma
    3in front lift, 2.5 rear lift
    Has anyone put two lift spacers together on the front of their truck? Would that even work or would it be to dangerous?
  2. Feb 12, 2017 at 8:15 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    That would be dangerous.
  3. Feb 12, 2017 at 8:49 AM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Not possible. You have less than 3" total to play with in terms of front end variation from OEM alignment before linkages and control arms bind up. You can barely get the front end re-aligned, going to a 2.75" spacer lift.
    Even with the 2.75" spacer lift, you still have to use the OEM length front strut - whether reusing the original, or going with an aftermarket replacement - it has to be the same length (more or less) as the OEM strut.
  4. Feb 12, 2017 at 8:52 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Being cheap is very expensive. Do it right.
  5. Feb 12, 2017 at 8:53 AM
    Steven07
    Steven
    Ohh okay I see. I had a friend who did that with his Ford and it seemed fine. But I wasn't sure if it was possible or even safe with the Tacoma's.
  6. Feb 13, 2017 at 9:25 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    NEVER stack your spacer lifts.
    On top of that, 3in spacers is the max you should raise your front before you start getting serious problems. More than likely, you'll be tearing CVs left and right.
  7. Feb 13, 2017 at 9:35 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
  8. Feb 13, 2017 at 9:49 PM
    SamGoingHam
    Sam
    Phoenix, Arizona
