lift question
Discussion in 'Suspension' started by socal19, Jan 6, 2010.
  1. Jan 6, 2010 at 11:58 AM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey guys I got a question.....I'm going to install coilover for 3 inch lift up front....now for the rear I was thinking about the ome/dakar 2.25" leaf pack........I was wondering with that will the rear sit higher then the front cause I want the front a little higher than the rear
  2. Jan 6, 2010 at 12:16 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    It would probably sit even, if not a little higher in the rear. Depends how high you set your c/o's.
  3. Jan 6, 2010 at 12:19 PM
    socal19
    California
    I'm going to set my coilover at 3 inches
  4. Jan 6, 2010 at 12:30 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    witht the cilovers set at 3", i personally think the rear would still sit higher with the 2.25" pack in the rear
    message someone here with stock setup and ask them to measure distances and compare!
  5. Jan 6, 2010 at 3:34 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    beware you might not like how the truck rides with the CO's cranked down to 3 inch lift
  6. Jan 6, 2010 at 3:42 PM
    socal19
    California
    Well what lift at 3inches will give u better ride quality
  7. Jan 6, 2010 at 4:30 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    stick with the CO's and just preload them to about 2.5, thats what i have mine at and go with a diff leaf pack, one that doesnt give ya so much lift
  8. Jan 6, 2010 at 6:03 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    well im assuming your talking about an 03 prerunner. if it is a a 5 lug then look at performancelifts.com, they have a fabtech 3" lift spindle. then you can run a better shock / coil combo up front give you 3" and a better ride. talk to other 1gen guys see if anyones running those spindles.
    just checked again. they have em for both 5 lug 2wd and 6lug prerunners. check em out do some research and ask other 1gen guys q's. good luck keep us posted
