Lift question!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lopedogg, Jan 13, 2010.
  1. Jan 13, 2010 at 11:57 AM
    lopedogg
    lopedogg [OP] Well-Known Member
    Spokane, WA
    '12 TACO TRD
    Hey guys, I was wondering what would be the easiest, cheaper way to lift without having to change too much and not loose ride quality. Would 5100's on all four corners and aal work ok? I'm not looking for anything too crazy..just a inch or two. Thanks!
  2. Jan 13, 2010 at 12:03 PM
    braggman7
    braggman7 Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    I have the same question. I want to do billies and an aal. i want lift but don't want any vibes, etc. but maybe thats impossible, i dont know. i had a 3 inch lift on my old 01 dodge and it rode like crap, but then again, it rode like crap before the lift.
  3. Jan 13, 2010 at 12:06 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    billies and an aal would be just fine. i just did billies set at .85 and the eibach springs to get about 2.5 of lift in the front and 2 inch aal in the back without vibes and still rides great
  4. Jan 13, 2010 at 12:09 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    For the money it is hard to beat the 5100 setup. The fronts will lift 2.5" and you can get an aal for the rear to match. Will clear a 285/75R16.
    www.wheelersoffroad.com
  5. Jan 13, 2010 at 12:22 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    with new wheels or wheel spacers to clear 285s and some trimming.
  6. Jan 13, 2010 at 12:28 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    5100 all around. It seems like from most people, after doing some aal things then they start to get driveline vibs/shutter which will need driveshaft drop or shims to try to cure..or even a new one piece
