LIFT question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cudason, May 27, 2010.
  1. May 27, 2010 at 6:44 PM
    cudason
    cudason [OP] Well-Known Member
    Vancouver
    TURD
    Eagle Alloy 050 series wheels. TRD fj shift knob Bilstein 5100 set @1.75 TRD CAI TRD seatcovers 2009 Taillights Xenon HID kit
    I have an 05 Tacoma. just purchased a new (used lift for it) I've got front bilstein 5100s, toytec diff drop and rear toytec blocks. No tsb rear aal. I want to set the billys at 1.75. the guy i bought the lift off purchased both the 1 inch and the 1.5 inch blocks. what do you guys reccomend if setting the fronts at 1.75. or should i set it at max and use the 1.5. all insight would be appreciated.
  2. May 27, 2010 at 6:47 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    1.75 with 1.5 rear.
  3. May 27, 2010 at 7:01 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I'd put the billies on at 1.75, then measure from center hub to fender, subtract .25" from that measurement for sag in a couple months, then see what the difference is in the rear and pick th appropriate block.
  4. May 28, 2010 at 4:07 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    x2..1" blocks with Billies at 1.75 will give the better ride quality. I would install the Billies first with it set at 1.75. Then measure the gap difference between front/rear to see if blocks are needed. That will help you determine which blocks to use. You may not even need the blocks if it's level. You really don't even need the diff. drop for that kind of lift.
  5. May 28, 2010 at 5:17 PM
    cudason
    Vancouver
    TURD
    debating doing the 3 inch...
  6. May 28, 2010 at 5:20 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    1 inch blocks 1.5 imo would be to big
