Lift Questions about an 09 Prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cfish, Oct 12, 2009.
  1. Oct 12, 2009 at 3:17 PM
    Cfish
    Cfish [OP] Member
    Rome GA
    09 PreRunner Timberland Mica
    5100s on all four corners, camburg spindles, 2" Toytec AAL, BFG T/A 285s, 17" Moto Metal 955s, Blue Dome Light mod, Huskey Floor Liners
    Hey, I'm new to the forum and I've been considering putting a lift on my 09 double cab prerunner. Originally I had wanted to do a 3 inch coil over- style lift, but I wasn't sure about UCA issues or other problems down the road. Also I might be interested in something a little higher. I want to spend the money, and do it the right way without a body lift or spacers so I don't have any problems down the road. After research and reading the threads on here, this is what I've come up with:
    Camburg 4" lift spindles
    Front and Rear Bilstein 5100s
    Rear 2" toytec add-a-leafs
    285/70/17 BFG All-Terrain T/A KO
    17x9 Moto Metal 955
    Questions:
    Problems with this setup?
    How much trimming (if any)?
    Ride quality?
    What would I have to adjust the shocks to to have a level ride?
    Suggestions or comments?
  2. Oct 12, 2009 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Looks like a good set up. You should leave the shocks at the 0" setting.
  3. Oct 12, 2009 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    and Welcome to TW! ;)
  4. Oct 12, 2009 at 4:16 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Thats the same setup i've been concidering! Although i'm going w/ the ProComp 7089 wheels and Total Chaos UCA's :thumbsup: Can't wait to see your pics, post em up asap.
  5. Oct 12, 2009 at 4:25 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    wasting your money with UCAs on a Spindle lift. the spindles give you 4" of lift and maintain stock geometry. So unless you plan on stacking a 3" there's no reason you will need UCAs to get your alignment right. Unless youre having issues with tires rubbing UCAs on the spindle lift. which is a posibility.
    To the OP:You will need Brake lines for the spindles and you should look into a shim and or Carrier Bearing drop. You should leave the 5100s at 0". but you will probably need an extra inch in the back to have a level truck Unless youre doing a 2" AAL on a TSB.
  6. Oct 12, 2009 at 5:53 PM
    Cfish
    Cfish [OP] Member
    Rome GA
    Thanks for the fast replies! Should I be concerned with my tires rubbing on the spindles?
    and I dont have the tsb so I'll look into it, or maybe a leaf pack in the future when I have the money
  7. Oct 12, 2009 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be fine with that size.
  8. Oct 12, 2009 at 6:03 PM
    PreRunnerSeth
    Apex, NC
    I think a custom leaf pack is the way to go with this. I have the 2" AAL on the back right now with 3" up front and it sits pretty level. The spindles push the wheels out a little so you should be fine as long as you get a wheel with the right backspace.
  9. Oct 12, 2009 at 6:15 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    i plan on doing that im about to order 5100s and AAL, i already got a set of 285 TrXus M/Ts just need the lift now
  10. Oct 12, 2009 at 9:18 PM
    socaltaco2
    socaltaco2 Active Member
    Sounds like a solid setup. I thought of getting the spindles, but dont like the fact that it pushes the wheel out 3/4". What color is your tacoma?
  11. Oct 13, 2009 at 2:27 PM
    Cfish
    Cfish [OP] Member
    Rome GA
    timberland green
    I went ahead and ordered everything but the spindles (still waiting on an email reply from camburg).
  12. Oct 13, 2009 at 2:29 PM
    mjp2
    mjp2 Living vicariously though myself Moderator
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I'm pretty sure Camburg is still settling back in after the offroad expo this past weekend. I'm waiting to hear back from them as well.
  13. Oct 27, 2009 at 2:44 PM
    Cfish
    Cfish [OP] Member
    Rome GA
    I called camburg and the guy there says that they make 2 models of the spindles- one for keeping the sway bar and one that gets rid of it... any suggestions? The guy on the phone said that the ride isnt going to change that much because im adding stiffer shocks.
  14. Oct 27, 2009 at 3:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you drive on the road often, keep the sway bar.
  15. Jan 17, 2010 at 4:11 PM
    Cfish
    Cfish [OP] Member
    Rome GA
    Thanks for all the help! I finally got around to buying everything (christmas and birthday definitely helped!) and I lifted it last night. I'm very happy with the results as of now, and plan on getting alignment done tomorrow morning.
    Here are some pictures.
    Before:
    After:
  16. Jan 17, 2010 at 4:15 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  17. Jan 18, 2010 at 4:42 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
  18. Jan 18, 2010 at 2:28 PM
    tacosuave
    tacosuave New Member
    09 PreRunner
    Looks great! I hope the installation went smoothly.
