Lift questions/advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flafos, Jun 29, 2021.
  1. Jun 29, 2021 at 6:49 AM
    flafos
    flafos [OP] Well-Known Member
    Gerald
    New Port Richey, FL
    2019 4x4 DCSB TRD Off Road cement
    I am going to lift my 2019 TRD OR DCSB. I have SCS stealth six's arriving today. (had the same wheels on my 2015 that got totaled) I am leaning towards the Bilstein 6112's in the front and 5100 in the rear with Deaver springs in the rear. I rather like the factory rake also.
    My questions are:
    How much lift in the front before you need to swap upper control arms?
    What other things, if any, will I need? Axle shims? anything else?
    Is there still an issue with the front Differential bearing grinding with a lift on the 2019?
    anything else I should consider?
    Not planning on putting bumpers on in the future.
    Thanks for your advice in advance.
  2. Jun 29, 2021 at 6:56 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Planning any hard core off-roading or just trails/camping areas and want the look? I do the light stuff and went with the Eibach kit, 2" in the front, 1.5" in the rear to maintain some rake and I really like it.
    flafos[OP] likes this.
  3. Jun 29, 2021 at 7:29 AM
    flafos
    Gerald
    New Port Richey, FL
    Nothing major, just light stuff.
  4. Jun 29, 2021 at 7:33 AM
    Aqualoon
    Minnesota
    You'll be fine with just a stage 1 kit then. Bilstein, Eibach, OME, Dobinsons, etc. which will all be fine with stock UCAs. When I had mine done I put in the ECGS bushing at the same time, some lift and never need to do this. I figured might as well do it at the same time.
  5. Jun 29, 2021 at 7:33 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    2" of lift in the front will be enough to compromise your assignment. You may be able to get camber/toe in but caster will be low. If you do significant highway driving it can be a chore to constantly input steering correction to go straight. Bump steer also gets stronger with less caster. You could lift, align, drive for a bit and see how it is. Not hard to add UCAs after
    71tattooguy and flafos[OP] like this.
  6. Jun 29, 2021 at 9:08 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Can’t go wrong with 6112’s OP. I went from 5100’s to 6112’s. Love it wouldn’t change a thing. I went with 600lb springs no plans of added front weight. Ride is great on and off road. Actually has softened out after a few months. After settle got a little under 2” no big deal. I have close to factory rake as well. Rake is good glad you are on board with that. No Bro lean when loaded :thumbsup:
    Hope this helps. Get UCA’s will help big time.
    Good luck
