Lift Questions.. (PLEASE HELP)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eddyb22, Oct 30, 2011.
  1. Oct 30, 2011 at 8:43 AM
    eddyb22
    eddyb22 [OP] Well-Known Member
    Ok so i am going to get a 3in suspension lift "rough country" and it says shocks are not required but i kinda want them.. should i get two aftermarket shocks and if so should i get a red boot cover or black? i have a silver trd sport.. I think red boot cover would look cool..? OPINIONS PLEASE :D
    Also would the ride quality be better with new shocks or is it not worth it??
  2. Oct 30, 2011 at 8:47 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Is your rough country lift a spacer lift?
    If your concerned about ride quality at all there are much better options.
    Black boot...
  3. Oct 30, 2011 at 8:49 AM
    eddyb22
    not real sure.. but i just thought the red boot would loom pretty bad ass because of the red trd sport writing..
  4. Oct 30, 2011 at 8:52 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You can get a better riding lift for comparable money
  5. Oct 30, 2011 at 8:52 AM
    wolfdog2314
    Brush Prairie
  6. Oct 30, 2011 at 8:54 AM
    eddyb22
  7. Oct 30, 2011 at 8:54 AM
    eddyb22
    what other lifts are better? share links..
  8. Oct 30, 2011 at 8:55 AM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    How much are you looking to spend?
  9. Oct 30, 2011 at 8:55 AM
    eddyb22
    300$$
  10. Oct 30, 2011 at 8:58 AM
    wolfdog2314
    Brush Prairie
    Same lift except with an AAL which is what you'll want.
    I'd get a pair of Adjustable Bilstein 5100's and set them to 2.5 up front. And an AAL and 5100's in the back. Call it good until you can upgrade your full front spring assembly with a new Coilover or eibach or OME springs.
  11. Oct 30, 2011 at 9:01 AM
    eddyb22
    my main question is should i get two shocks or just keep stock ones?
  12. Oct 30, 2011 at 9:09 AM
    XPOTRPR
    XPOTRPR @ADDoffroad
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    CHECK BUILD
  13. Oct 30, 2011 at 9:11 AM
    eddyb22
    alright thanks.!
  14. Oct 30, 2011 at 9:39 AM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I would do the Procomp over a spacer lift for sure. You get new coils, AAL's, and four new shocks. It's a great value for under 500 bucks. Having said that, the spring rate is pretty high and some people say they aree too stiff to be comfortable and provide over 3 inches of lift which is not good.
    I would buy front 5100's for your stock coils and an AAL for now. You can buy Eibach coils later for 150 bucks and make it a little better while keeping shocks you already paid for. You can also add new longer rear shocks when funds are available. Total for all that should be 550 to 600 bucks and IMHO will be a better riding setup than the Procomp.
  15. Oct 30, 2011 at 10:27 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    i wouldnt go procomp or rough country. i think you should save your money
  16. Oct 30, 2011 at 11:10 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Big difference in those two.
  17. Oct 30, 2011 at 11:40 AM
    jr114
    Jon
    SoCal
    Truck
    well the rough country is a spacer= bad ride
    and ive had the procomp and i hated it. that specific procomp is a pile. 720#front springs give way to a really crappy ride
  18. Oct 30, 2011 at 11:59 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Can't argue with that. It's too bad because if they would have got the engineering right it could have been a good little kit. I wonder if anyone has ditched the 720 lb coils for some Eibach or OME ones with a lighter spring rate.
  19. Oct 30, 2011 at 1:44 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    I bought this lift on my old truck, wasnt impressed. It is inexpensive, and it does its intended purpose for the money, however there are many, many better lift options. I ended up replacing mine after about 6 months.
  20. Oct 30, 2011 at 4:40 PM
    jr114
    Jon
    SoCal
    Truck
    when i did have the lift, i contacted procomp and the rep told me that if i were able to find another coilover that would have the correct length when compressed you should be able to swap it out. so that could be an option for some people out there.
