Lift Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaes843, Mar 29, 2012.
  1. Mar 29, 2012 at 2:40 PM
    tacomaes843
    tacomaes843 [OP] Well-Known Member
    03 Prerunner SR5
    3.5' lift in the front w/ Bilstein 5100 Shocks & Eibach Coils, 1.5' in the back with blocks & billies. Tinted windows. Tinted Tail-lights. Blacked out corner lights. Uws tool box. Whip Antenna. 2nd gen 16' wheels. Flowmaster 40 dual exhaust. 1.25' Wheel spacers all around.
    Hey guys I'm looking to lift my 2002 ext cab prerunner and I'm wondering whether to go with the 2.5 bilstein set up in the front and 2 inch blocks in the back, or 3 inch suspension rough country lift. And you think I could fit 33's with the billies? Thank you!
  2. Mar 29, 2012 at 3:03 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    yes you can. but it will be a rough ride. 33 will need trimming. why not settle for eibach springs with bilstein @ 0 and add a leaf to the rear instead of the block. dont go cheap. you will regret.
  3. Mar 29, 2012 at 7:37 PM
    tacomaes843
    03 Prerunner SR5
    How high will both the billstein and the eibach springs do? That's true, add a leaf's quality is much better than blocks.
  4. Mar 29, 2012 at 7:38 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    setting the 5100's to "0" and letting the eibachs do the lifting will get you around 3.5" of lift.
    they will also perform much better than the 5100's at their highest settings.
    33"s may rub, though.
  5. Mar 29, 2012 at 7:44 PM
    tacomaes843
    03 Prerunner SR5
    Thanks man! That sounds good. I like your yota! Mines the same color!
