lift questions :)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08BlackenedTaco, May 13, 2012.
  1. May 13, 2012 at 8:56 PM
    08BlackenedTaco
    08BlackenedTaco [OP] Well-Known Member
    High Point, NC
    Prerunner Murdered....
    14" magnaflow maxflow muffler, intake mod, black headlight mod. VHT Nightshades tail lights, painted stock rims.
    so my 3" procomp lift is not sufficient. i want 2-3 more. so my question is...... can i put a 2-3" spacer on the front without needing new UCA's? the back I'll probably go with blocks. and i dont wheel. and i actually like more stiffness in my ride. so need new UCA's with spacers or no? I'm thinking probably the answer is yes but i wanted to make sure.
  2. May 13, 2012 at 9:02 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    x2
  3. May 13, 2012 at 9:03 PM
    cjasu
    cjasu TW resident Camel
    CJ
    Buies creek NC/seminole county
    06 prerunner soon to be moded
    camo seat covers
    Procomp even makes a 6" so id just uo grade and keep/sell the current lift
  4. May 13, 2012 at 9:10 PM
    08BlackenedTaco
    High Point, NC
    I dont see the problem stacking spacers on a lift? a lift is just a bigger coil and strut. if you put spacers on stock coils and struts. whats the problem with putting them on an aftermarket set? unless its the issue with UCA's...
    I'm not going to spend $1000 to drive down the street 3" higher. lol and those are drop bracket lifts. I have a prerunner. Spindles are a grand also so thats a negative. Up high, Cheap is the idea here.
  5. May 13, 2012 at 9:12 PM
    08BlackenedTaco
    High Point, NC
    now say you put billies on your truck at set at 2.5 and then tried to stack a spacer on it, i would say your a dumbass. but with the aftermarket strut and coils i have the full range of motion still so why not? i dont go driving over curbs and shit.
  6. May 13, 2012 at 9:13 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    6" from the spring\spacer combo will ride beyond terrible and will not be geometry correct
  7. May 13, 2012 at 9:18 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Well then why is your 3 inch you already have not sufficient. not tryin to be a dick but if the only thing you are doin is ridin down the road and the toughest terrain you see is the bump in the driveway why go another 3 inches. It would be a terrible ride and and risk in snapping a strut
  8. May 13, 2012 at 9:30 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Why are you asking if you don't want to listen to these guys' opinions? I think 3 inches is more than enough lift. The only cheap safe thing you can do is get a body lift and look like a moron
  9. May 13, 2012 at 9:35 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    With a spacer on the top it will not put any preload on the spring, but will hyper extend the shock on full droop.
    Top plate spacers extend the length of the assembly to where, when the vehicle rebounds, it will over extend the shock, thus risking breakage.
    The bigger the spacer, the greater the chance of carnage.
    A link that will answer everything spacer
    If you're asking for a 6" lift out of spacer without a drop bracket because it's cheap, then the answer is that is impossible. This is a fact: spending a lot of $= high quality lift. Best suggestion is do more research before buying a lift, we have a grip of threads already addressing this. Best way to lift a 2wd is a spindle and rear leaf pack, start with that idea in mind and work around it.
  10. May 13, 2012 at 9:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    x1000 your asking a question but then your posting like you know this is a good idea
    can you say no downtravel, crazy steep angles, terrible alignment, every boot that holds grease ripped
  11. May 13, 2012 at 9:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    sit on a phone book
  12. May 13, 2012 at 9:54 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    If you really want 6" then you're way better off selling your 3" lift now, and then buying a 6" lift
  13. May 13, 2012 at 9:55 PM
    CayucosTacoma
    :rofl:
  14. May 13, 2012 at 9:56 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    No need to argue, I think the OP just doesn't understand
  15. May 13, 2012 at 10:02 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    Although it would be a horrid idea to do the stacking, you would shit your pants trying to put the procomp coil/coilovers in with a spacer lift on top even if you took the spindle apart from the uca for install... stick with what you got or get a 6" drop bracket since you dont need any offroad assistance with the lift.
  16. May 13, 2012 at 10:10 PM
    Sunner
    Sunner Well-Known Member
    I have no experience with lifts yet but stacking spacers still seems sketchy to me. Good advice here OP, Id take it. Good luck man.
