Lift Questions
Discussion in 'Off-Roading & Trails' started by Martinmann21, May 14, 2013.
  1. May 14, 2013 at 11:39 AM
    Martinmann21
    Martinmann21 [OP] Member
    09 TRD off road
    I don't really want to mess with the current suspension in my '09 quad cab 4x4. Does anyone know if it is sufficient enough of a lift to just add 2inch leveling spacers in the front and adding a leaf to the back? It seems like a simple method.
  2. May 14, 2013 at 1:26 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Depends on what your plans are for using the Taco, but yes that is lift. Spacers aren't ideal but they are lift. You will probably want some longer shocks in the rear though, unless you will only be doing street driving and mild offroading.
  3. May 14, 2013 at 1:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    5100's would be the way to go for a descent cheaper priced lift. Try to stay away from spacers.
  4. May 14, 2013 at 1:35 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Sorry should have mentioned that. I am running 5100's on all 4 corners with an add a leaf in the rear. Like DeeKay21 said, 5100's would be a better option than spacers.
