Lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by factory909, Jun 25, 2015.
  1. Jun 25, 2015 at 7:38 PM
    factory909
    factory909 [OP] Well-Known Member
    2013 DCSB/4WD/4.0
    5100/AAL/EIBACH/LR UCA
    I've got a 2013 DCSB 4x4 that I am wanting to lift. I researched for a few days and finally placed this order:
    Eibach 1.6" Springs
    5100's all around
    LR UCA's
    and the Toytec AAL for the rear
    I got to reading some more, am I going to need the top spacers to get a level stance with this setup? It looks like I am going to get 1.6" + 0.85" which nets 2.45". I am currently sitting at 20" center to fender in the front, and 21" in the rear.
    So after the lift I should be at 22.45" in the front, and 22.50"-23.00" in the rear. Will the spacers get me leveled? AND do I need to factor in the Tacoma lean?
    Thanks for any help
  2. Jun 25, 2015 at 9:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can remove the overload springs from the rear for 1.5" rear lift (vs 2") to make it more level. Personally at about 2.5" lift front I wouldn't add any more front lift. But that is personal preference.
