Lift Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AtxLakeTaco, May 1, 2017.
  1. May 1, 2017 at 10:47 AM
    AtxLakeTaco
    AtxLakeTaco [OP] Texas Toyota Coalition
    Tres
    ATX
    Black DCSB Prerunner
    5100's,887's,etc.
    Been on here for a while, currently have a 3 inch lift. But I was wondering whats the biggest sized tires that I can run on it?
    ChadsPride likes this.
  2. May 1, 2017 at 10:49 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. May 1, 2017 at 11:01 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    There's multiple answers.
    Some will say 35s some will say 33s some will say 255/85s
  4. May 1, 2017 at 11:03 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    thank you for the genuine answer, I'm fine with doing a CMC, and hammering pinch weld. Will that be sufficient for 35's?
  5. May 1, 2017 at 11:04 AM
    TREDFOOT
    TREDFOOT Well-Known Member
    Tristin
    2005 Red Tacoma TRD 4x4
    3 inch OME Suspension Lift and 1 inch Bilstein Body Lift
    I have 33s on a 3 inch Suspension lift and 1 inch BL. I did a little bit of trimming but it still rubs a little in reverse and about half crank or more.
    ChadsPride and AtxLakeTaco[OP] like this.
  6. May 1, 2017 at 11:07 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Me personally I would stay with 33s I don't want to mess with regearing that I see a lot of members needing with 35s
  7. May 1, 2017 at 11:08 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    I can get down with that, I'm 2wd. So 35's would be purely for looks.
  8. May 1, 2017 at 12:58 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    I kid... sort of...
    If you run 33's and you don't give a shit about rubbing at full lock, or full compression... you can just run 33's with no modifications. (except the 3" lift you currently have installed)
    If you want to go off-road, or avoid rubbing when you take a tight 180 to do another lap around the Mall Parking Lot, you're gonna want to chop your cab mounts.
    If you don't give a shit about that rubbing, it won't hurt anything really... so you don't NEED to chop anything.
    This is, of course, my own personal experience with my own personal 4x4 that I burned through some tires and some suspensions learning as I went.
