Lift Recomendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dk6487, Jan 5, 2012.
  1. Jan 5, 2012 at 7:20 PM
    dk6487
    dk6487 [OP] NorCal Member
    David
    Novato, CA
    08 Silver 4X4 TRD Sport w/ Tow Pack
    Pioneer Z110BT Nav/DVD H.U., Sub Box by Mr. Marv w/ amp and 10" Sub, Rear-Leaf TSB, L.E.D. Guage Mod, 3" OME Lift Kit w/ 885, Total Chaos UCA's
    So I've read a lot about lifts on here and I've found lots of useful information but I'm still completely undecided. I have about $700 to spend and I'm somewhat mechanically inclined. I'm looking for aroun 3" of lift (I've read that a lot are actually 2.5 which is fine.) I do practically zero off roading but I would like to change that to 2-3 times a year off road. I have a 2008 Dbl Cab LB 4X4 with the rear leaf TSB completed (4 leafs). I don't want to do spacers because from what I read they're horrible. I'm also by BF Goodrich 265/70/17 Rugged Terrain A/T. I was looking at the Toytec website but agin there are a lot of choices out there. Thanks in advance for your help.
  2. Jan 5, 2012 at 7:44 PM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    Bilstein Adjustable lift kit with 5100 shocks and add-a-leafs, 265/70R17 is the Tire size I went with too.
  3. Jan 5, 2012 at 11:25 PM
    dk6487
    David
    Novato, CA
    Thanks for the advice so will this lift kit be ok with the AAL that's designed for the tsb?
  4. Jan 5, 2012 at 11:30 PM
    dk6487
    David
    Novato, CA
    Sorry forgot the link.
    Option 1:
    How would option 2 fair?
  5. Jan 5, 2012 at 11:35 PM
    dk6487
    David
    Novato, CA
    Now I'm wondering if I should get a kit or order things seperately. Thanks again wolfpack.
  6. Jan 6, 2012 at 4:53 PM
    dk6487
    David
    Novato, CA
    Ok after checking funds I've decided to go with toytec's OME Suspension lift Kit. 885's for the front, AAL for Tsb. Does anyone know if the kit comes with new U-bolts? Also do I need the rear shock stone guards?
  7. Jan 6, 2012 at 5:02 PM
    dk6487
    David
    Novato, CA
    Do You know what size U-bolt I'll need. they sell 7.5" or 8.5". It says 7.5" works with the AAL but doesn't specify if it works with the TSB also in place.
  8. Jan 6, 2012 at 5:10 PM
    dk6487
    David
    Novato, CA
    No worries, you've been a ton of help already.
  9. Jan 7, 2012 at 1:28 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    I have a related 5100-lift question.
    I have the rear TSB and 265/75/16's on a 8" wide rim. I want (something) in the front to level the truck and eliminate my tire rubbing.
    My question is, if I go with 5100's, is it standard to install two (where needed, in this case, the front), or replace all four shocks with 5100's? Also, if replacing just the front, what is the method for determining how much lift is needed to level the truck? If I were to eye-ball it, I'd say 1.5-2" is needed, but I'm assuming there is a more precise method, least I pull out of the shop with my nose in the air and my ass dragging behind me :eek:
    I'm a PreRunner, so off-roading isn't really an issue/option, but I do tow and haul a bit. The most I've hauled to date was 1,000lbs, before my new tires and rims but after the rear TSB.
  10. Jan 7, 2012 at 1:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    IIRC, the middle setting levels 2nd gens out pretty good.
    To check your measurements, measure from the center of the wheel hub to the top of the fender
    if youre not lifting the rear, you don't have to get the 5100s (though, they do have a better ride)
  11. Jan 11, 2012 at 6:16 PM
    dk6487
    David
    Novato, CA
    Hey everyone. I finally pulled the trigger and ordered the OME lift kit from toytec assembled with 885's, 1.5" AAL for TSB, and Dif Drop. I'm also going to order some UCA's but am not sure which to get. Total Chaos sounds like one of the best but I do very light off roading and mostly freeway drives. Are LR UCA's an okay supplement to save $200. I have a DBL Cab LB w/ 265/70/17 tires. Also do I need longer bump stops?
  12. Jan 15, 2012 at 2:19 PM
    mb_edgar
    mb_edgar Well-Known Member
    Manhattan Beach
    Tacoma TRD Off Road Pack
    6000k headlights and fog lights, L.E.D lightning all around, satoshi grill, hella 5100's behind the grill, pnasonic in dash, dual fosgates ps3's behind back seat, powder coated back bumper.
    I have a Related question about the 5100's
    So here's the whole story I'm riding stock besides the rear TSB im running 285/70/r16 at the moment which will be swapped out soon. I'm looking to add 5100's to the front set at 2.5 the question is can Literally just order the set of 5100's and put them in or do i need anything else. I know the alignment must be done but keep in mind im swapping out the tires literally days after so alignment will be done then
    Just want to make sure im not missing anything thanks guys
