Lift recommendations
Discussion in 'New Members' started by JohnnyC92, Mar 2, 2023.
  1. Mar 2, 2023 at 10:59 PM
    JohnnyC92
    JohnnyC92 [OP] New Member
    2023 TRD Sport 4x4
    Looking to lift my truck in order to clear some 285s. I’m not looking to crawl rocks but I want something that would handle your everyday dirt roads and bumpy trails. Don’t want to break the bank either. Any recommendations as far as lift/shocks/coils, new UCAs or not, etc? Would I be good with preload collar lift kit? Also, why are thoughts about the trd lift kit Toyota sells. Thanks!
    buckhuntin-tacoma likes this.
  2. Mar 3, 2023 at 5:32 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Mar 3, 2023 at 5:44 AM
    mushroom_man7
    mushroom_man7 Well-Known Member
    oh sweet summer child...if youre asking about rock crawling and a toyota lift in the same thread, you might want to consider learning about what you want to do instead of blindly jumping into this. that being said theres hundreds of threads on this subject.
  4. Mar 3, 2023 at 5:47 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
  5. Mar 7, 2023 at 9:09 AM
    Vladivostok
    Vladivostok for sale
    Vlad
    Bend, OR
    2020 Tacoma TRD Off-Road
    For Sale: low-key overland build (done june 2021)
    Hey - I went slightly bigger (with 33s (mickey thompson baja boss 33/12.5/17)) - but would have done the same lift if I stuck with 285s (assuming on a stock trd 17" rim). I went with a toytec full suspension 2.5" shocks front/rear bigger leaf pack in the back. Worked out fine, cost $5k installed). In retrospect I'd spend more because good suspension makes all the difference in your day-to-day. I'm very happy with this setup but it could be better and is worth the extra money (if you plan on keeping the truck long-term). Cheaper shocks will need maintenance sooner which cost $, too. The only other thing to think about is your weight - if you know that it'll help with the install because the last thing you want is to set it up one way and then the ride hight (front-rear) is not what you're looking for. Hope this helps.
    JohnnyC92[QUOTED][OP] likes this.
  6. Mar 7, 2023 at 9:15 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Welcome to TW!
    285's require cutting more than lifting. Tons of threads on this. Use Google search with tacomaworld in the search bar.
    Ricardo13x likes this.
