Lift Review - Help Needed (Bilstein 6112, AP Expo)
Discussion in 'Suspension' started by snowmanwithahat, May 27, 2016.
  1. May 27, 2016 at 12:33 PM
    snowmanwithahat
    snowmanwithahat [OP] Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Hey everyone, I've been looking at lifts for a bit now and ended up cutting down my expectations from a TC LT setup to what I have on this google sheets spreadsheet. I've conceded that the truck needs something, but flat out just will never be an offroad monster while I own it unless I go with a 3.5" + LT setup or SAS it... so while it's still mostly a road vehicle with occasional offroad trips a MT setup like this is what I have in mind.
    Please, if you could, take a look at the items I've picked out and let me know if I'm missing something obvious. My biggest concern is that I'm either missing something or that the AP expo leaves are going to be way too much spring rate for what I have (essentially no weight most of the time, occasionally loading up a trailer or the truck bed with wood)
    https://docs.google.com/spreadsheets/d/1QgMlY3PYn5-YaxGPIsZuBezx8wNwogssRVa5PplpEO4/edit?usp=sharing
    Item
    Bilstein 6112
    Bilstein 5160
    U-Bolt Flip Kit w/ Timbren
    UCA
    AP Expo Leaves
    CB Drop
    Brake Line Extension
    Front Timbrens
    Thanks in advance!
  2. May 28, 2016 at 1:27 PM
    snowmanwithahat
    Bump, looking to order parts Tuesday
  3. May 28, 2016 at 1:35 PM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    What's your budget? And how much lift do you want? The 6112 is a good setup. But not really much travel over stock depending on the preload.
  4. May 28, 2016 at 4:18 PM
    snowmanwithahat
    Budget is very flexible. I've accepted that everything worth getting is going to be around or over $3,000. This setup would be for a truck that still sees mostly road use but I really want it to perform at speed in the sand and flex well on slow, tight and rocky trails.
    Pretty much want it to do everything lol
  5. May 28, 2016 at 4:55 PM
    Jrobertson
    James
    Stock. For now.
