Lift Setups Recommendations Plz
Discussion in 'Suspension' started by TacomaWestCoast, Feb 4, 2021.
  1. Feb 4, 2021 at 1:20 PM
    TacomaWestCoast
    TacomaWestCoast [OP] Active Member
    2020 TRD OffRoad Barcelona Red
    Recommendations for a lift kit?
    I have a 2020 Tacoma TRD offroad.
    Im planning on putting a bed rack and tent on here really soon and running tires around 33in.
    I have heard the Eibach pro kit one with aal in the rear is a good option I just want more opinions.
    Also not trying to do anything crazy off road or expensive!
    Thanks again in advanced!
  2. Feb 5, 2021 at 12:27 PM
    TacomaWestCoast
  3. Feb 5, 2021 at 3:03 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    There’s a little more work to run 33s than put on lift and tires. I recommend really deciding on how you’re gonna use the truck and then determine how much lift you want and go from there researching different lift kits in the budget you decide on.
    TacomaWestCoast[OP] likes this.
  4. Feb 5, 2021 at 3:14 PM
    TacomaWestCoast
    Camping and mild off roading.. i dont mind doing body work either if needed
  5. Feb 5, 2021 at 3:20 PM
    gotoman1969
    Usually about 2.5 “ most guys will recommend ucas also to help with alignment and tire fitment along with a cmc. If you don’t want to deal with that I’d stick around 2” and 265 or 275 tire.
  6. Feb 5, 2021 at 5:02 PM
    TacomaWestCoast
    Any basic lift set ups you recommend?
  7. Feb 5, 2021 at 5:25 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
  8. Feb 5, 2021 at 5:29 PM
    TacomaWestCoast
    Yeah I just want the lift also for when I put weight on the vehicle
  9. Feb 5, 2021 at 6:20 PM
    WestCoastMango
    WestCoastMango Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Howdy,
    best bang for buck setup IMO is the Bilstein 6112/5160. If you plan to just lift the vehicle purely for aesthetics and don't plan to run your vehicle hard, I'd look into the bilsteins 5100's as they will be a slight upgrade compared to your stock shocks.
    Last option is a spacer lift which is the cheapest route. I know tacomaworld despises these lift but they are honestly not that bad if you just plan on using your vehicle for the road and very little off road use.
    TacomaWestCoast[OP] and daluvian like this.
  10. Feb 6, 2021 at 3:31 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Call the folks @HeadStrong Off-Road they answer your questions.
    Just make sure you buy your lift from them. :fistbump:
  11. Feb 12, 2021 at 2:52 PM
    JDPNW
    JDPNW Well-Known Member
    S. Oregon
    2021 DCSB TRD OR Cement KDMax-Pro
    Eibach 2.0,SPC UCA,ECGS,ATS 4/1 rear leaf,5.29
    I have a 2021 and just got done with DIY'ing my lift,
    Eibach 2.0 coilovers
    (came with sway bar drop down)​
    JBA UCA's
    (watch wheel backspacing for larger tires)​
    Eibach Pro Truck Sport rear shocks
    Headstrong 1.5" AAL
    I went with coilovers for the fine-tune and adjustability without having to tear anything apart. I also installed the ECGS bushing just because I figured why not while I had everything tore apart. It's only been a week although I'm happy thus far.
