lift shocks and lift coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma_1500, Feb 16, 2017.
  1. Feb 16, 2017 at 8:40 AM
    tacoma_1500
    tacoma_1500 [OP] Member
    Is it okay to run bilstien 5100 lift shocks and 2-3 inch lift coils to get around 4- 5 inch of lift? I wanna be able to clear 33's
  2. Feb 16, 2017 at 11:46 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Never preload lift coils more than the 1st notch on 5100s. Some people agree and some will say dont preload at all and leave them at 0.
  3. Feb 16, 2017 at 11:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No. If you are 4x4, you can't lift over 3" due to the angle of your CV axles unless you go to a drop bracket lift.
    If you are 4x2, look into maxtrac spindles. That'll lift you 4".
    Either way, you won't clear 35s without doing some cutting, so be prepared for that.
  4. Feb 16, 2017 at 11:49 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    May as well remove the shocks and install cinder blocks at that point.
    taczilla and EatSleepTacos like this.
  5. Feb 22, 2017 at 7:31 AM
    tacoma_1500
    i dont wanna clear 35's. i wanna clear 33's
  6. Feb 22, 2017 at 7:43 AM
    KJM_SLC
    KJM_SLC Member
  7. Feb 22, 2017 at 7:54 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    If you want to leave the truck parked and just stare at it, go ahead. If you plan on driving it at all, do NOT stack lifts.... As mentioned, beyond 3" is a can-o-worms. Don't open it!
    You'll have to resort to a drop bracket lift beyond 3" and I'm not a fan. 33"'s will rub, even with 3" of lift.....It'll rub when you turn steering, when you hit a bump, when you flex suspension off roading, etc....
    Cab mount needs to be cut at minimum. BTDT, have 33"'s on my truck with 3" of lift.
