Lift shop quotes (laughable)...
Discussion in 'Suspension' started by pgiroua, Jul 10, 2012.
  1. Jul 10, 2012 at 9:20 AM
    pgiroua
    pgiroua [OP] Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    I have gotten (4) separate quotes from local lift shops here in the Houston area. Below are the results:
    1) $1,000
    2) $600
    3) $480
    4) $350
    For those interested, I am asking a price to replace the spindles and struts up front, new leaf pack and shocks in the rear. They would also have to mount and balance new rims and tires and do an alignment.
    Why such the broad range? What is everyone's opinion of where the price SHOULD be at?
  2. Jul 10, 2012 at 9:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The range can be due to a lot of things, namely the shop's experience with that type of work and how busy they are. If they're not making markup on the parts, some shops don't want to bother installing someone else's parts.
    In my opinion, $80+/- for an alignment, 1 - 1.5 hours to install new shocks all around so figure $150ish, $40 - $50 to mount and balance 4 tires and 1 hour to swap the spindles so another $100. Roughly, I'd guess your total should be in the neighborhood of $400 before taxes.
    There is some efficiency gained with doing all the work at once which my guesstimate does not take into account. There is also some risk with rust on older trucks in the salt belt or near salt water (not sure if you're near the ocean).
  3. Jul 10, 2012 at 9:30 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    Are you supplying the parts?
    I would say you are looking at 6 hour job, average shop rate is $80 an hour... so 6*80= $480
  4. Jul 10, 2012 at 9:40 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Host a meet in texas and ask some locals to come help you do it. Supply food and beverage, wrench on the truck, and make some new friends :)
  5. Jul 10, 2012 at 9:45 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    I would be supplying all of the parts.
  6. Jul 10, 2012 at 9:46 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Should I be leary of the $350 price?
  7. Jul 10, 2012 at 9:49 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    My father in law has the tools and the know how to get it done but the shop quoting me $350 also will warranty their work for 25,000 miles. I would also need to bring it somewhere to mount/balance the tires and get an alignment. This in itself would be roughly $150-$200.
  8. Jul 10, 2012 at 9:51 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
  9. Jul 10, 2012 at 9:54 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Ask locals for help. Meet some TWers in your area & learn more about your truck. I'm sure some have done lifts, Then all you need are the tires mounted & balanced followed by an alignment.
  10. Jul 10, 2012 at 9:58 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    2 & 3 seem to be the only reasonable quotes on that list for what you want done depending on whether the alignment is 1 time, 1 yr, 3 yr or lifetime.
  11. Jul 11, 2012 at 9:45 AM
    DevL
    DevL Well-Known Member
    What are the shops in question... I live in Houston and can probably give some insight on the shops.
  12. Jul 11, 2012 at 10:17 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    $1000 = American Wheel & Tire
    $600 = Cutten Customs
    $480 = Offroad Outlaws
    $350 = 2920 Customs
  13. Jul 11, 2012 at 10:36 AM
    DevL
    2920 Custom is NOT an offroad shop. They are a tint/stereo/alarm shop. I watched a similar shop, not that one, attempt their first wheel and suspension work on someone elses vehicle while I had my alarm installed... swore I would never use a stereo shop for mechanical work after seeing that.
    Your most expensive option will do good work. Had friends use em but did my install myself due to price. They are only like 5 min from me.
  14. Jul 11, 2012 at 12:56 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You're better off doing your own work.....have some local members come over if you already have the tools. You'll learn more about your truck that way, save money and KNOW it's done right. Those are all pretty straight forward swaps (all you're doing is removing and replacing)!
