lift size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by P_Tree, Aug 10, 2010.
  1. Aug 10, 2010 at 11:29 PM
    P_Tree
    P_Tree [OP] Well-Known Member
    Tyler
    Beavercreek, Oregon
    1995 1/2 Tacoma
    Custom plate bumper Trail Gear sliders/rear bumper Magnaflow exhuast Warn M8000 Winch Rocklights 8" Hella Fogs Cargo Bed Basket Tint 35 12.5 KM2s SAS Swap CB and PA Hids 8k highs and lows Fogs 12 inch alpine sub Spec intake Blacked out Grill, Emblems, etc...
    How big of a lift do i need to fit 33 12.50?
  2. Aug 10, 2010 at 11:41 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Really just depends how much you want to cut, how much you want the tires to stick out, and if its for actual use or just looks. Quite a bit will depend on the wheels as well.
    I know they aren't 33x12.5, but you can probably get away with 285/75R16 (32.8x11.2) with some spacers. I've seen these on stock wheels with a 2.5" lift with out spacers and it really is a lot of rubbing. I'd probably stick a 1" spacer or get wheels with a little more backspace if I were to do it.
    I'm sure its doable with a 3" lift though, but will require a bit of trimming.
  3. Aug 11, 2010 at 12:01 AM
    P_Tree
    Tyler
    Beavercreek, Oregon
    1995 1/2 Tacoma
    i heard i might be able to get by with 33 10.5s
  4. Aug 11, 2010 at 1:32 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
  5. Aug 11, 2010 at 1:39 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    If you pull the trigger on 33's you must also realize you are going to lose a lot of power and regearing would be recommended. I wanted to do 285/75/16 but after reading up about the extra costs that 33's require, I'm going to settle with a slightly smaller tire (265/75/16) and not have to worry about extra maintenance
  6. Aug 11, 2010 at 2:02 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    hes probly got 15'' wheels so 285/75/16 are probly a no go. to the OP i put 33x12.5 on my truck when wheelin and ive got a 3'' lift, they are pretty tight even with trimming
  7. Aug 3, 2011 at 12:58 PM
    bogged out
    bogged out Member
    chackbay ,LA
    3 inch leveling with 33 boggers
    i have a 3 inch lift with 33 boggers and never rub at all
  8. Aug 3, 2011 at 1:00 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Welcome to TW.
    How did you find this one year old thread? :confused:
  9. Aug 3, 2011 at 1:01 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    X2
  10. Aug 3, 2011 at 1:05 PM
    bogged out
    bogged out Member
    chackbay ,LA
    was looking if i could fit 35 on my lift i have now
  11. Aug 3, 2011 at 1:08 PM
    TexasTacoma37
    If you get an aftermarket front bumper, and cut your fenders out a few inches (the actual metal fenders), then you could probably pull it off. There are a few who have done it.
  12. Aug 3, 2011 at 1:11 PM
    bogged out
    bogged out Member
    chackbay ,LA
    well i just put a 1.5 body lift ant plus i have that leveling and what kind of front bumper. iv looked everywhere for one but no luck
  13. Aug 3, 2011 at 1:15 PM
    TexasTacoma37
  14. Aug 3, 2011 at 1:20 PM
    bogged out
    bogged out Member
    chackbay ,LA
    thanks alot i will order one tonight. and also i need new tires bad. i have boggers right now and i want something less aggresive but still a mud tire.
  15. Aug 3, 2011 at 1:24 PM
    TexasTacoma37
    I would check with them to see if anyone has fit 35's on a 3" lift with it before you buy it. Like i said above, you "probably" could get it to work. That's not a guarantee.
  16. Aug 3, 2011 at 1:33 PM
    bogged out
    bogged out Member
    chackbay ,LA
    well if i cant fit 35's then i will just slap some new 33's on it. i ripped my bumper off the other day so i need on bad.
  17. Aug 3, 2011 at 1:34 PM
    bogged out
    bogged out Member
    chackbay ,LA
  18. Aug 3, 2011 at 7:01 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    You don't need ANY lift to fit 35's. It's called :laser:
  19. Aug 3, 2011 at 8:50 PM
    bogged out
    bogged out Member
    chackbay ,LA
    Lol my trucks messed up enought.lol
