lift spacer question....pics on the way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gixxer73, Sep 27, 2009.
  1. Sep 27, 2009 at 8:57 PM
    gixxer73
    gixxer73 [OP] Well-Known Member
    darren
    kodak, tn
    2009 tacoma double cab SR5 4x4
    spidertraxx, ultimate lift kit by Toytec, LR UCA's. Kenwood 5140 Double Din, WeatherTec Floor Liners. Custom Box Build for 12 Inch PS3 with Punch 250. 15% tint all but front winshield, which is 35%, Katskinz Leather, SR5 Sockmonkey Decals, BLacked out badges, blacked out wheels, LED third light.
    I have a stock 09 double cab 4x4. Putting on 3" lift toytec front spacers and rear add a leaf. To run a 285 70 r16 or anything bigger on my stock rims do I need to go ahead and order spacers and if so what size???
    Thanks guys!!
  2. Sep 27, 2009 at 9:00 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    yes order some spidertrax spacers. not only will you be able to clear the uca's your stockers will have an aggressive stance
  3. Sep 27, 2009 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Spacers are not a very good idea. Pre load spacers ride rough, and top plate spacers can damage ball joints and other components.
  4. Sep 27, 2009 at 9:12 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    x2! if you can afford it get the ome coil lift kit from toytec
  5. Sep 28, 2009 at 12:45 AM
    gixxer73
    darren
    kodak, tn
    OK guys, re thought it and I'm going to order the ULTAC 2005 kit for $1149.99. Once installed will be using my stocker rims. And guys are saying I need to get WHEEL/TIRE spacers by Spydertrax so my tires will clear the UCA's right??
    So billstiens in front and rear with add a leafs and it comes with pinion shim, drop kit, and sway relocate and then me adding the WHEEL/TIRE spacers I should be good to go???
    The size of the spacers should be like 1.25 inch right??
    THANK YOU GUYS A BUNCH FOR THE ANSWERE, NEVER OWNED A TACO OR RAISED ANYTHING FOR THAT MATTER SO YOUR ADVICE IS APPRECIATED.:D
    Ultimate lift kit for 2005 & UP Tacoma
    Price per Unit (kit): $1 149.99
    Number kits in packaging:1
    Number kits in box:1
    ULTAC-2005
    Ultimate lift package for 2005 & UP Tacoma
    Our engineers selected these products for a complete lift for your Tacoma. This kit offers the best ride and performance on and off road.
    Includes:
    TTAFCS-6005 - ToyTec/Bilstein Adjustable coilovers featuring Bilstein 5100 maintenance free shocks, adjustable from 1 to 3 1/2" lift.(spanner wrenches included for adjustment). Preset 2 1/2" to 3" lift. No spring compressor needed; fully assembled for a bolt on front lift.
    SBR-129 - sway bar relocates
    TAC-DR-05 - Front Diff drop kit
    TAC-AL - ToyTec Rear "long" add-a-leafs featuring anti friction pads for quiet ride
    Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
    TT-RS - rear axle degree shims for proper pinion angle alignment Ultimate lift kit for 2005 & UP Tacoma
    ULTAC-2005
    Includes:
  6. Sep 28, 2009 at 1:33 AM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Your from Kodak and in the Air Force? Wow, I'm from Sevierville. Right now im stationed in England. Will be back in TN next week. Are you planning on getting uca's? I spoke with neubs, we should start a group buy on these. He had an awesome deal on the toytec ultimate lift with light racing UCA's. http://www.tacomaworld.com/forum/to...over-kits-ultimate-lift-lr-ucas-new-post.html
  7. Oct 4, 2009 at 7:54 PM
    gixxer73
    darren
    kodak, tn
    Not active duty Air Force got out in 1998!!
    Ordering the Ultimate from Neub?? I think was his handle, using stockers with spidertrax 1.25 spacers all the way around so from what I understand my UCA's will not be a issue. And it will be babied. true offroading 35% of the time maybe and slow. I'm no speed demon off road, I like the crawl/climb aspect.
