Lift Spindle questions
Discussion in 'Suspension' started by Lentsnh, Jun 5, 2010.
  1. Jun 5, 2010 at 5:23 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    If I have 3" +- of lift and I put on 4" Lift Spindles, does that put 4" of lift on top of the 3" +- lift?
    How hard are they to put on? What's the time it takes?
    Is there a sellers market for stock spindles?
    Can I run 35" MT tires with stock wheels with the Lift Spindles?
    Thanks
  2. Jun 5, 2010 at 5:33 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    1) Yes.
    2a) They can be a PITA if you don't have patience, tools, or know what you're doing.
    2b) It varies on who is installing, how many sets of hands, and how much you know. I would say plan at least a weekend around it just to be safe. If all goes well roughly about 8 +- hours.
    3) Not too sure what you mean by this question but your best bet is to just buy from the vendor since it's rare to come up on some used ones.
    4) You can if you have the 3+-" lift with the spindles and have some major rear end lift.
    Hope this helps.
  3. Jun 5, 2010 at 6:40 PM
    Lentsnh
    So i will have 7.5" of lift total in the front? Wow thats great!
    Thanks for the help Jacob!
    only $500 left to go!
  4. Jun 5, 2010 at 7:08 PM
    Lentsnh
    Anybody else have anything to add?
  5. Jun 5, 2010 at 7:11 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    You'll need extended brake lines.
  6. Jun 5, 2010 at 7:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You will need to regear to run those tires. Maybe some 4.56's
  7. Jun 5, 2010 at 7:23 PM
    Lentsnh
    Oh yes, I know that. They are like $10 so not too crazy but thanks Colton. :thumbsup:
    Would the stock gears handle the 35"s until I can regear?
  8. Jun 5, 2010 at 7:26 PM
    Incognito
    VA
    No problem, the Camburg ext. brake lines are $90 if you were wondering...
  9. Jun 5, 2010 at 7:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I guess they will but you will loose a lot of power and it is just harder on the whole drive train. You would be fine for a little while though, plus a prerunner will be fairly cheap to regear.
  10. Jun 5, 2010 at 7:42 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    You don't want 7.5" of lift dude. I'm just warning you :D
    Keep it at 4-4.5".
  11. Jun 5, 2010 at 7:51 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Your COG will be pretty high and the stress on the truck is something to consider, referring to the tires mostly. Also what are you going to do for the rear?
    Yes. I know a guy that's been running 35's on stock gears for some time now.
  12. Jun 5, 2010 at 7:58 PM
    Lentsnh
    So should I drop down my Billys a notch? If I get the Lift Spindles?
  13. Jun 5, 2010 at 8:01 PM
    Lentsnh
    Yeah I can see that. My carrier bearing needs help so that will make me fix it. :eek:
    I may get All-Pro Rear Leaf pack. I'm not sure yet. I'll have to see what everyone else's setup is.
    Wow. Thats alot.
  14. Jun 5, 2010 at 8:09 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Dude. Lift it 4" from the Camburg Spindle and set your 5100's to .85 and you're golden. You'll have a real nice lift in the Front and have the 5100's juts set right.
    However, if I were you. I'd get the Camburgs and a nice coilover and leave the coilover set @ the lowest setting. Awesome ride.
  15. Jun 5, 2010 at 8:15 PM
    jacob_wood
    Jacob
    2010 SSM DCLB
    Spindles=4"
    5100's=2.5" (max)
    + whatever else you may have.
    This is what you want. 7.5" is wayyyy to much.
    Yes, I had spindles + 5100's at 2.5" and it was terrible. I now just have the lift spindles and it's perfect.
    For the rear set up you're going to need a lot more than just the AP leaf pack. My plan originally was to get shackle flip kit+alcan leaf pack+shackles to even it out. That's just too hard to do all at once. If you get that height I would recommend new UCA's because of the strain on the stock ones. I'm sure you have seen my truck at the 6.5" with nothing in the back. I HIGHLY recommend you to NOT have that much height.
  16. Jun 6, 2010 at 8:38 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    Sorry dont mean to steal your thread, but i plan on getting the same spindles but instead of billys 5100s, i am going to get icon coilovers and for the rear i am going to to get a custom leaf springs made from alcan and get 35" tires. My question to everybody is, i heard that you can get a 10% discount from camburg if you mention that you are a member here, is that true? Also did anybody get them from somewhere else at a discounted price? Also what extended brake lines do you recommend other then the $90 one from camburg. Thanks..Mike
  17. Jun 7, 2010 at 9:16 PM
    David10MGM
    David10MGM Active Member
    David
    Tennessee
    10 PreRunner TRD Off Road MGM
    Camburg spindles, bilstein 5100's @ 1.75, All-pro 3in leaf, 1.5in block, 5125's
    This is the set-up that I am debating. Already have the 5100's, just need the spindles. ;) I like a little bit of rake, so what rear set-up could someone recommend? I would like to do a leaf pack but need about 4in. in the rear.
  18. Jun 7, 2010 at 9:34 PM
    mnudo200827
    Michael
    Corona, CA
    I am going to get a custom leaf pack from alcan, they can custumize it just the way you want the leaf pack to be, wether it be for hauling, off roading, just a daily drive, its all fully custom, and they can put lift in it. i got quoted $500 for both.
  19. Jun 7, 2010 at 10:00 PM
    David10MGM
    David
    Tennessee
    Sounds good. Thanks.
  20. Jun 9, 2010 at 6:32 AM
    mnudo200827
    Michael
    Corona, CA
