Lift spindles, 5100s, leaf packs, blocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mirraman, May 1, 2012.
  1. May 1, 2012 at 1:30 PM
    mirraman
    mirraman [OP] Well-Known Member
    Tim
    Ventura
    98 4Runner Limited 4X4 e-locker :-)
    99 4Runner springs all around: 1" over factory.
    Hello Everyone,
    I was just wondering if anyone has this sort of setup. It will be a long time coming, but I eventually want to get my Taco up around 6" without a fabtech, etc. lift. I'm thinking: Maxtrack 4" spindles and 5100s up front, Dakar leaf packs and blocks in the rear. Is anyone running this kind of setup. Gotta save the money up for a while so I just wanna make sure it's acheivable. Any input would be helpfull.
  2. May 1, 2012 at 1:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Check out All-Pro Expos rather than Dakars with blocks.
  3. May 1, 2012 at 1:35 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Go with the all pro don't do blocks
  4. May 1, 2012 at 1:40 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yes, that lift setup is possible. But look into leaf packs rather than blocks.
  5. May 1, 2012 at 1:42 PM
    mirraman
    Tim
    Ventura
    I mentioned leaf pack with blocks because I can't stand having the rear sag. I want it level or even a touch high in the back. I'll check out those All-Pro Expos though.
  6. May 1, 2012 at 1:44 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The expos will give you 4" in the rear.
  7. May 1, 2012 at 1:47 PM
    Pugga
    Massachusetts
    It's possible, it depends on what you want to spend and what the final usage will be. You could also do lift shackles to gain some height. They allow for better flex but also wear out the leaf pack quicker as a result. That being said, blocks will do the same thing, they wear out leaf packs quicker. They act as a torque block and give your axle that much more torque to apply to the leaf pack. This causes axle wrap and eventually premature wear.
    The Expos are a pretty strong leaf pack. Like any spring, they'll eventually start to sag but they should resist it for a while depending on your driving conditions.
  8. May 1, 2012 at 2:05 PM
    mirraman
    Tim
    Ventura
    I thought you couldn't put lift shackles on the 2nd gens!?! I would have done that instead of blocks! Anyways, I do a lot of street driving. It's my daily driver. When I have the chance i love gettin her dirty though. I'd say off road runs once every two to three months.
  9. May 1, 2012 at 2:06 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    shackle flip
  10. May 1, 2012 at 3:05 PM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    you'll also need
    coils
    UCAs
    extended brake lines
    if i'm correct
  11. May 1, 2012 at 3:10 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    IMO you should go with the 4" spindles with 5100's at 1.75" lift. This will get you close to 6" and you should not need new UCA's for alignment. For the rear, like others said, get the All-Pro expo leaf packs. If the rear is a little low for your liking with the expo's, do the shackle flip or a 1" block. The spindles come with new brake lines and you can get brake lines from All-pro for the rear. You will certainly need longer shocks for the rear.
  12. May 1, 2012 at 3:30 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Get a alcan custom spring lack before you do a shackle flip kit
  13. May 1, 2012 at 4:58 PM
    Pugga
    Massachusetts
    Yep, you'd need a shackle flip for a second gen.
    I believe you're correct, you'll need all that if you want to get to 6" of lift wiithout using a drop bracket lift. Although, I don't think you'll necessarily need new UCAs. You'll get 4" of lift from the spindles and you can go 2" of lift without needing the new UCAs unless there's something I'm unaware of when using a spindle lift...
  14. May 1, 2012 at 7:39 PM
    mirraman
    Tim
    Ventura
    I actually already have LR UCAs. Gonna put 'em on this friday. Next on the list is probably spindles. I do need better shocks though so maybe a set of 5100s. Where can I find info on the shackle flip? Or, if it's easy, what do I do? I wouldn't mind getting rid of the blocks I have in the rear. What are some good rear shocks for the shackle flip?
  15. May 2, 2012 at 2:21 PM
    Dromlace
    Michael
    Montgomery, AL
    extended length 5100s. and it's somewhere in the Buy/Sell/Trade.. i'll see if i can find it.
  16. May 2, 2012 at 2:24 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    close to that
    4" maxtracs
    bilstiens front and rear
    1.5" aal
    toytec adjuster thing with eibach red coils
  17. May 2, 2012 at 7:57 PM
    mirraman
    Tim
    Ventura
    NICE!! Your truck looks awesome :D
  18. May 8, 2012 at 1:57 PM
    DreDog
    DreDog Well-Known Member
    Andrew
    ill sell you my camburg spindles and 5100s for 1200 bucks, and help you install the spindles.
    they only have 3000 miles on them
  19. May 29, 2012 at 10:57 PM
    DreDog
    Andrew
    bump?
    im still trying to get rid of my set up to go stock
