lift success stories ?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoandy, Feb 23, 2012.
  1. Feb 23, 2012 at 4:41 PM
    tacoandy
    tacoandy [OP] Member
    Andy
    bristol pa
    3" rev tek
    Wanting to lift my new reg cab 2011 , and am getting scared off by other posts , need to hear from some lift wo problems ... ( put a donahoe (icon) lift on a fj I had and worked great)
  2. Feb 23, 2012 at 4:58 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    What is your concern? People who have 0 issues will also have 0 insight for you... you run the risk of problems every time you modify a vehicle. If you aren't willing to take that risk you shouldn't lift it. Many people do it and are very happy with it
  3. Feb 23, 2012 at 5:02 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    OP, thats cause you dont hear about all the "good" experiences, only the bad.
  4. Feb 23, 2012 at 5:03 PM
    ross123
    ross123 Well-Known Member
    fort bragg
    i just lifted mine. i put OME 886's with dakars in the rear. i used a diff drop kit and a CB drop kit. i also put 285/75/16's on it. that was 3 weeks ago. so far i have no vibes at any speed. i had some rubbing but the shop that installed the lift did a cab mount chop for me. so thats taken care of. my CV angles are alittle steep, but im hoping once i get my bumper put on it will help with that. so in a nut shell im very happy with the lift and so far no problems! check out pics in my sig
  5. Feb 23, 2012 at 5:03 PM
    garcm329
    garcm329 Well-Known Member
    Mario
    Rancho Cucamonga
    06 T4R
    Icon 2.5 front coils, toytec aluma series 2.0 rear shocks and toytec HD springs. ARB air locker in the rear. 285 70 R17 Kenda Klever RT tires on IVD bronze 6 speed 17” wheels. Wilco spare tire carrier.
    ^^^ very true... you should just take the negative as a learning opportunity so when you have problems you will know what to expect and how to fix it. I think the majority of people here have had some type of problem after lifting their truck but are still happy they made the choice.
  6. Feb 23, 2012 at 5:04 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Depends on lift and such 5100's seem good and heard lots good about toyotec
  7. Feb 23, 2012 at 5:06 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    :popcorn: also about to add some 5100's all around, and for front lift...
  8. Feb 23, 2012 at 5:11 PM
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2022 Tacoma TRD Pro
    2022 Tacoma TRD Pro ......................................... 94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    886 coils
    Front Diff drop
    Rear N182 shocks
    OME trim spacer
    LR UCA's
    285/75-16's
    Plus Armor, bumpers, ect.... I wheel her hard and I have had zero problems with anything suspension related. Actually zero problems with anything with the truck.
  9. Feb 23, 2012 at 5:13 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    I bought the procomp 3 inch lift. It came with front strut/coil spring, sway bar relocate brackets, the "toyota lean" shim, rear ad-a-leafs with everything needed to re-pack your leafs, and rear shocks.
    Install took me and abuddy about 6hrs being slow and precise. The actual amount of lift I got was 4 inches! Measured and double checked. Lol. Hasn't settled that much either, it has about 4k miles on it.
    The ride is imo a little better than stock. The rear is a tad stiffer but.. its a truck. Handles great on and off road (at least moderate off road) haven't done much crazy stuff.
    Abs and vsc liked to kick on a lot in inappropriate times. A better alignment and a re calibrated zero point censor fixed that.
    No complaints at all after that. And at ~$500 you get a lot for the price. Hope this helps a little.
  10. Feb 23, 2012 at 5:13 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    I bet 50% of this site has a lift with no issues...
  11. Feb 23, 2012 at 5:28 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I'll chime in here.
    I lifted a 05 taco with 80K on the dial, and the problems i have had so far are vibrations.
    Here is my experience in a nut shell.
    First vibrations were the carrier bearing. Lowering it solved allot of issue with torque related vibrations. Here recently about 6K after lift, I lost both front wheel bearings. That was a $1400 repair bill. This can be attributed to both the high milage, and the added leverage of larger wheels and tires. Is the vibrations gone, No, i am still on a quest to find the little bastard. I dropped the front Diff to make sure there was no issues with the CV joints, but that did nothing. For the hell of it, i had the all U-joints replaced, nope not it either, so i decided to replace the carrier bearing hoping it was shot, nope not it either. Tires were wearing uneven, so i took it in and had it aligned, it was barley out, had tires rotated while it was there. Still not it. Vibration i still have is really harmonic, it increases in frequency from 30-80mph.
    Now the million dollar question, would i do it again?
    Hell Yes, the truck looks and performs fantastic on and off road. Yours being a 2011, i would do it in a second, because you have no wear and tear on the truck.
    I will update you to what my issue is, i am going to adjust the Coil overs to see if i can get that harmonic vibe under control. After that, i may have look into binding in the front diff, or transfer case issue and pinion angles.
    Good luck,
    You always have to Pay to Play!!
  12. Feb 23, 2012 at 5:43 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Lifted mine with the Toytec Ultimate Kit. As of right now, only issue I have is the common shudder when accelerating from a standstill. I did not install the diff drop and my CV's look surprisingly good (the angles, that is). My lift is about 3'' back, about 2.5'' in the front btw.
  13. Feb 23, 2012 at 5:48 PM
    rcbs204
    The torque related shutter you are feeling is from your carrier bearing. Drop it and it will fully disappear, guaranteed.
  14. Feb 23, 2012 at 5:52 PM
    808hiker
    Justin
    Big Island, Hawaii
    Really? I bought the CB drop that Toytec sells and installed on the truck the same time when I lifted it. Tried removing it too, but the shudder was the same
  15. Feb 23, 2012 at 5:52 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I lifted my truck 1/2" by going from 245s to 265s...no issues. :p
  16. Feb 23, 2012 at 5:54 PM
    tacoandy
    Andy
    bristol pa
    3" rev tek
    Lifted , yj , fj , bronco , no problems , prolly go w ome setup ... Keep it a little saner with the taco , Thanx
  17. Feb 23, 2012 at 5:56 PM
    rcbs204
    You need about an Inch to get rid of it, you can just buy some steel like i did, and lower it a 1/4 inch at a time. I took mine off like five times before i got it just right. Every truck is different. Some lucky guys lifted and never had a problem, either that or they live on a really rough gravel road and can't tell the difference!!!
  18. Feb 23, 2012 at 6:01 PM
    808hiker
    Justin
    Big Island, Hawaii
    Interesting. I'll try lowering it a bit more and hopefully that gets rid of the problem.
  19. Feb 23, 2012 at 6:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    TX Baja will be sporting a 2" lift. Gives you an idea of what Toyota feels comfortable with using stock upper control arms.
  20. Feb 23, 2012 at 6:09 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Watch out what you read. I bought my lift (AAL on the rear and Bilstein 5100's) from someone on here who had them on a double cab and had no problems. They only sold them cause they upgraded to a better lift. I put it on my regular cab and had all kinds of vibes and noises. Only thing I can chalk it up to is the short driveline. With that said, I've seen a few lifted regular cabs on here who claim they don't have problems.
