Lift suggestion on a budget?
Discussion in 'Suspension' started by Eull-ming QC, Jul 4, 2016.
  1. Jul 4, 2016 at 4:07 PM
    Eull-ming QC
    Eull-ming QC [OP] Member
    Trepanier
    Tacoma trd sport 2013
    Yo everybody im New here and I want to lift my tacoma trd sport 2013 but I want some things not to expencive for now and some things look good and Will not to much modification to do I need some things that work good some one have idea for me ? Sorry for my bad anglish :(
    ChadsPride likes this.
  2. Jul 4, 2016 at 4:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Welcome!! What kind of budget are you working with for a lift?
  3. Jul 4, 2016 at 4:31 PM
    Eull-ming QC
    Trepanier
    Around 300 or 400 à was tinking to put like spacer 3 inch in front and 1.5 block on rear but I dont if it work good on road and if it Will make some problème after
  4. Jul 4, 2016 at 4:34 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Plenty of people run spacer lifts, and they're fine for certain applications.
    You can't do any real off roading without risking over extending the shocks and blowing them.
    You also have to be ok with the fact it'll ride pretty rough.
    If you're fine with those things, then a spacer lift will work for you. If you want to spend a little more ($650) then you can do it "right" but still on a budget.
    ChadsPride and tcBob like this.
  5. Jul 4, 2016 at 4:35 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  6. Jul 4, 2016 at 4:49 PM
    Eull-ming QC
    Trepanier
    Ok tanks body and the 650 more its for better shocks or its à réal lift kit
  7. Jul 4, 2016 at 4:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  8. Jul 4, 2016 at 4:55 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Bienvenue à Tacoma World :cheers:
  9. Jul 4, 2016 at 5:57 PM
    Eull-ming QC
    Trepanier
    Thanks for all body I take à look at that
    Et marci bin haha c est popire ste tacoma world la
  10. Jul 6, 2016 at 6:27 PM
    Eull-ming QC
    Trepanier
    Some body know wat is the bot paturn à want to put 1.5 inch weel spacer on my trd sport 2013
  11. Jul 6, 2016 at 6:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    6x5.5 bolt pattern. Spidertrax as well as Bora are popular, as long as they're hub-centric.
  12. Jul 6, 2016 at 6:34 PM
    Eull-ming QC
    Trepanier
    5.5 its the diameter ?
  13. Jul 6, 2016 at 6:35 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not sure what those numbers actually mean, just that it's the bolt pattern. If you google 1.5" wheel spacer tacoma, you'll find your options.
  14. Jul 6, 2016 at 6:37 PM
    Eull-ming QC
    Trepanier
    Ok thank you verry much men thanks again for your help
  15. Jul 6, 2016 at 6:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No problem man!! I'm on here all the time, so just reply to this thread and I should get back to you.
  16. Jul 6, 2016 at 6:41 PM
    Eull-ming QC
    Trepanier
    Ok haha thanks again :thumbsup::cheers:
  17. Jul 6, 2016 at 6:47 PM
    Eull-ming QC
    Trepanier
    I found spacer from weeltech do you tink its good lol
  18. Jul 6, 2016 at 6:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Never heard of them, so I can't comment on them. I will say not to skimp on the part that's literally holding your wheels on your truck. You don't want that failing driving down the highway!
  19. Jul 6, 2016 at 6:55 PM
    Eull-ming QC
    Trepanier
    Ok I Will look at this thanks
  20. Jul 7, 2016 at 4:55 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I ran a spacer lift on my truck for quite a while. It didn't ride any different than it did "stock"....Same EXACT ride....If you off road much, you can run the risk of running out of shock travel well before you run out of suspension travel. That can be remedied with a spacer on the bump stop equal to the thickness of the top plate spacer..... 99% of the horror stories you hear about spacers are people just parroting what they heard someone else rattling on about. Spacers aren't the best way to lift a truck, but they are perfectly acceptable for on road and LIGHT off roading, especially on a tight budget. I did almost 53,000 miles with a spacer lift, did a fair share of off roading, and had ZERO problems. Mine was an $100 "EBAY kit"....(2" spacers/1"blocks)
    Finally, after 70,000+ miles, the stock shocks began to wear out as they would even if left "unlifted". I do a lot of interstate highway driving, on concrete roads, and that isn't easy on shocks...I replaced them with Bilstein 5100's, OME 885X coils, Deavers 2" AAL, and a home made 1/2" "lean spacer" on the front left. Ride is excellent. Handling is excellent, and off road performance is all I could hope for. With struts pre-assembled, I spent $733 on that setup. I also added a Ubolt flip kit for another $80 investment. The "new" lift was purchased through Headstrong Offroad. (Talk to Marie)
    You can do Bilstein 5100's in one of their lifted positions, do the assembly yourself, use stock coils (which I don't recommend) and get as much as 2-1/2" front lift. This preloads the coils to gain lift and will result in a stiffer ride. The OME coils give a much smoother ride while raising the truck with LONGER coils instead of stiffer.... For the same money as a rear blocks, you can add a 1-1/2" or 2" add-a-leaf and get a slightly better result. They'll give you more load capacity along with the lift. (Not a LOT of capacity increase, but some none the less) With blocks, you'll need new (longer) ubolts. That's a great excuse to go with the ubolt flip kit!
    A complete suspension "kit" is a far better choice, but sometimes the budget makes our choices for us. Spacer lifts don't get much respect, but they aren't nearly as bad as many will portray them.
