Lift Suggestions
Discussion in 'Suspension' started by jswmsw10, Nov 21, 2010.
  1. Nov 21, 2010 at 4:57 PM
    jswmsw10
    jswmsw10 [OP] Well-Known Member
    Jeremy
    Tn
    I have a 06 DC TRD Sport. Im looking to do a 3" lift. My options are OME, Pro Comp, or a kit with OME springs, 5100s, and AAL.
    Im not sure which one rides the best, if anyone running either of these set ups can let me know what you think please. Im gonna run 33s under it also. Thanks everyone
  2. Nov 23, 2010 at 2:02 PM
    jswmsw10
    Jeremy
    Tn
    Bump anyone?
  3. Nov 23, 2010 at 2:11 PM
    stephejm
    stephejm Member
    justin
    chesapeake, va
    well what kind of wheeling are you going to be doing? are you on a budget? i mean me personally i think that if your on a budget OME would work out best, but others may have a different opinion.
  4. Nov 23, 2010 at 2:19 PM
    764mike
    764mike Well-Known Member
    NJ
    2008 Toyota Tacoma Double Cab
    I thought anything other than stock springs the Billys should be at 0.
  5. Nov 23, 2010 at 2:20 PM
    jswmsw10
    Jeremy
    Tn
    I just go to hunting stands nothing hardcore at all, not really on a budget if I was going with the OME springs, 5100s, and the AAL set up I was gonna purchase some UCA later. But not sure how any of them ride either. Lookin for close to a three inch lift.
  6. Nov 23, 2010 at 4:02 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ome has good road manners and is priced good
  7. Nov 23, 2010 at 5:07 PM
    jswmsw10
    Jeremy
    Tn
    OME 3 inch kit is what your talkin bout I'm guessing?
  8. Nov 23, 2010 at 5:12 PM
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    i have pro comp 3 inch with 33's on 20's...ride is ok but it is a little rough sometimes
  9. Nov 23, 2010 at 5:17 PM
    jswmsw10
    Jeremy
    Tn
    Not sure what kit to decide on. The pro comp fits.your 33s so I know it will fit mind. The OME springs and 5100s will only give me 2.5" max right? Im gonna need 3" for 33s
  10. Nov 23, 2010 at 5:30 PM
    francis1291
    im not sure bout the OME springs...all i know is that i got a 3 inch and my tires only scrub the mud flap...i had to get a 1/4 wheel spacer cuz they were scrubbing on the UCA
  11. Nov 23, 2010 at 6:40 PM
    stephejm
    stephejm Member
    justin
    chesapeake, va
    well, i wouldnt suggest mixing lifts, thats just me personally. because certain springs are made for certain shocks. althought when it comes from front end to rear end, you can. i would suggest the rear OME dakar spring pack.
  12. Nov 24, 2010 at 7:25 AM
    jswmsw10
    Jeremy
    Tn
    Guess I will go with pro comps lift then.
