Lift suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Johnson1, Jul 6, 2016.
  1. Jul 6, 2016 at 9:43 PM
    Johnson1
    Johnson1 [OP] Member
    Jake
    2003 Tan Toyota Tacoma
    So, been looking at a bunch of lifts lately. Want to get my truck higher, just unsure what to do. I already have a 1.5 inch leveling kit in. I've been pondering the thought of a body lift because there isn't much more room to work with as my shocks go. Heard lots of different things about body lifts...good and bad. I'm looking to go about 3 more inches as I'm on a budget. Any suggestions help.
  2. Jul 6, 2016 at 9:51 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Welcome to tw. Do some research in the suspension forum. You will learn a lot about the good and bad and price ranges for possible lifts. Spacer and high body lifts are not a good option imo. If you don't wheel and just want it for looks get some adj. Bilstiens 5100 and a aal and call it good or a even better option would be a OME SUSPENSION set-up. Depends on all you want to do with your truck. Tons of info on here though. Use the search tool and you will find many threads on this exact topic. Good luck.
  3. Jul 6, 2016 at 9:58 PM
    eon_blue
    Azusa, CA
    Don't go with a body lift. A Bilstein 5100 suspension lift is relatively affordable as far as suspension lifts go and are safer, more practical and better looking than a body lift.
    You could keep your stock springs, get 5100's (adjustable in the front from 0-3") all around for $400 or so and an add-a-leaf for the rear for another $150-$200 to even it out.
    Or do what I just ordered today...5100's all around, OME 881 coils up front, 3 AAL in the rear for 2.5 in. of lift. $850ish out the door from Headstrong Offroad (includes new bushings and u-bolts, and pre-assembly for the front shocks/coils).
