Lift suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Prime_Time, Apr 4, 2017.
  1. Apr 4, 2017 at 7:20 PM
    Prime_Time
    Prime_Time [OP] Member
    Brandon
    Maryville, Tennessee
    Black 2009 reg cab tacoma
    I am starting a build on an '09 reg cab, but know very little about what tires would be best for me and I know nothing at all about lifts. I know I've been looking at getting 33" tires, just not sure what kind. I will not be off road much, mostly just highway driving, no idea what type of tires are best. Also, I've seen a trend with 3' lifts eith 33's, but like I said, I know nothing about lifts. Could anyone explain ehat would be best for me in the long run regarding both of these?
  2. Apr 4, 2017 at 7:25 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  3. Apr 30, 2017 at 4:13 PM
    CHarrison32
    CHarrison32 Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
  4. Apr 30, 2017 at 7:04 PM
    Pigpen
    Dan
    Northwest Montana
    It's not worth lifting a Tacoma.
    youcantseeme likes this.
  5. May 2, 2017 at 7:56 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    You're doing a good job.
    Pigpen[QUOTED] likes this.
  6. May 2, 2017 at 8:15 PM
    Justinlhc
    Justinlhc Not looking for a relationship
  7. May 3, 2017 at 9:46 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    This should be the default auto-response for every time one of these threads is posted.
