Lift then wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Falcon016, Jun 25, 2018.
  1. Jun 25, 2018 at 10:28 AM
    Falcon016
    Falcon016 [OP] Well-Known Member
    2017 Magnetic Gray Metallic TRD Off-Road
    Just looking for some insight from fellow TW members.
    Do I save for a lift or go ahead and get wheels then lift? I have the budget for wheels currently and I am feeling the urge to do something different on the Tacoma. Lots of Tacomas on the streets now where I live and I want to separate from the pack. What's the consensus?
    Thanks,
    Falcon
  2. Jun 25, 2018 at 10:34 AM
    Globo206
    Globo206 Member
    Globo206
    2017 Black Tacoma TRD Off-Road
    Lift then wheels for sure. Doing the lift first lets you put some bigger wheels and tires under
    remgu2000, xxTacocaTxx and na8rboy like this.
  3. Jun 25, 2018 at 10:37 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  4. Jun 25, 2018 at 10:44 AM
    Falcon016
    The wheels I am looking at getting will be the same wheels I will use when I lift and get bigger tires. I've got a set of 265/75/16 KO2s on at the moment with about 15k miles. Post lift I plan on making the 285 switch. I could sell the current KO2s but planned on running them full life.
  5. Jun 25, 2018 at 10:44 AM
    Falcon016
    I've been waiting patiently and reading so much about lifts that I feel ya..
  6. Jun 25, 2018 at 10:48 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Wheels is my last item for mods when I get there. Have you decided on which lift your going with?
  7. Jun 25, 2018 at 10:50 AM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    unlike other trucks....Tacomas dont look terrible lifted on stock wheels........so you can lift it, and get some wheels later.
    thats what im doing.....trucks lifted 3"....and im waiting until my tires need to be replaced and then fit fatter ones on.
  8. Jun 25, 2018 at 10:51 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Depends on what deal you find first! I found a pair of SCSs that I bought used. Threw on the shoes and rubbed a little while til I found a barely used lift!
  9. Jun 25, 2018 at 11:17 AM
    Falcon016
    Looking like Fox Stage 3 w/ icon mini pack.. Still researching though.
  10. Jun 25, 2018 at 11:21 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Good choice I had the Icon AAL before dakars. Rode great handles bumps like a champ...loads not so much I could put a lawn chair back there an see some sag. The dakars ride better but a little stiffer.
  11. Jun 25, 2018 at 11:36 AM
    Falcon016
    Can you describe stiffer? Provide an example from stock to dakars? I know it's all subjective but what's your experience? I'd really like to save up and not get the AAL, will probably end up doing that.
  12. Jun 25, 2018 at 11:43 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Ya it is hard to describe..stock going over a speedbump or railroad tracks the rear end would buck like a bronco an feel like a kidney punch. Dakars soak it up you feel it but assend stays planted. Best I can do you have to ride in a truck with dakars to know what I'm describing.
    Falcon016[QUOTED][OP] likes this.
  13. Jun 25, 2018 at 11:51 AM
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
    I had mine lifted 3in and had to wait 2 weeks for my tires/wheels to come in. I hated my truck with the stock sport tires/wheels during that time. If you can fit the wheels/tires you want without a lift I would do that first.
    Falcon016[OP] likes this.
  14. Jun 25, 2018 at 11:56 AM
    Falcon016
    This is what I will probably do. I want 285s but I will live with the 265s and then upgrade the tires when I lift.
  15. Jun 25, 2018 at 11:57 AM
    Falcon016
    That is all I really needed to hear. I go over tracks regularly. Stock is awful.
  16. Jun 25, 2018 at 12:00 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Aal helps it but Dakar is night an day difference with that type
    of thing so I'd buy once plus you get more lift. Aal is 1.5-2 Dakar is 3.
  17. Jun 25, 2018 at 1:40 PM
    Falcon016
    How do you think the Dakar would before compared the icon RXT pack?
  18. Jun 25, 2018 at 1:48 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Not sure don't know much about it:notsure:
  19. Jun 25, 2018 at 1:49 PM
    Falcon016
    I'll use the famed search bar and see what comes up. Thanks for the responses.
  20. Jun 25, 2018 at 1:53 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Lift. Spend more on it so you get a good performance upgrade not jsut look and feel, then you can add the wheels later, as you will likely spend more on those too.
    :spending:
