lift/tires for mild, not wild set-up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jinzo Ningen, Sep 28, 2020.
  1. Sep 28, 2020 at 5:20 PM
    Jinzo Ningen
    Jinzo Ningen [OP] Well-Known Member
    2017 Quicksand Tacoma TRD Off Road
    working on it... :-)
    Looking to get slightly taller/wider tires than the stock TRD OR is set up for.
    Based on those who've done it, how tall and wide can I go before I start having to mess with steering geometery and lifting, etc.
    I like the BFG Ko2 and found a slick wheel I love from Black Rhino called the Armory that matches my Quicksand paint almost perfectly. It's 17x9, so what are my tire height/width options? Doable or will it require lotsa changes?
    Thanks.
  2. Sep 28, 2020 at 5:39 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Bilsteins 5100’s , Eibach great lifts and you can still go out and have fun on the trails IMO.
    GOOD LUCK OP
  3. Sep 28, 2020 at 5:44 PM
    gcsrellis
    gcsrellis Well-Known Member
    2016 White Tacoma Limited 4x4
    You can fit a 275/70/17. The wheels are the biggest factor though. You want a wheel with about a +4 offset. It's the sweet spot for not rubbing.
  4. Sep 28, 2020 at 5:52 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    IIRC those wheels are very very heavy
    Mr-Paul likes this.
  5. Sep 28, 2020 at 7:43 PM
    Jinzo Ningen
    Yeah. 29lbs for 16x8 and 35lbs for the 17x9.5 that I leaned towards.
    Of course, out of the hundreds (if not thousands) of rim styles I've looked at, I went and fell in love with of the heaviest ones made. LOL.
  6. Sep 29, 2020 at 1:04 PM
    Jinzo Ningen
  7. Sep 29, 2020 at 1:20 PM
    gcsrellis
  8. Sep 29, 2020 at 2:32 PM
    Sharpish
    Brian
    I show 39 for the 17 and 34 for the 16
