Lift tires rims combo
Discussion in 'Suspension' started by EmoSlayer, Sep 30, 2009.
  1. Sep 30, 2009 at 5:41 PM
    EmoSlayer
    EmoSlayer [OP] METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    Ok, I have finally made up my mind after about 2 months of hours and hours of reading through TW, literally
    so what do you guys think of this combination, it's mostly going to be on the road and light trails in northern PA, I didn't want to cheap out and get spacers, but I don't want to spend an arm and a leg, and I do want to have proper alignment.. so anyways here is what I came up with..
    LIFT:
    3" Pro Comp Suspension Lift (no spacers)
    http://4wheelonline.com/Products.aspx?CategoryId=92436&ProductId=249893
    440.00$
    LR UCA's <-- I don't really want any wandering on the road
    450.00$
    Front Differential Drop <-- reduce wear on cv boots
    30.00$
    TIRES: BFG M/T KM 285/70/17
    http://4wheelonline.com/BFGoodrich_Mud_Terrain_KM_Tires.351.12468
    Do you think these would be in stock?? Can't find em anywhere else, really like these tires
    820.00$
    RIMS: 17x9, 4.5" BS, 6 on 5.5, non hubcentric
    http://www.4wheelparts.com/Wheels/R...s=209&t_pt=100021&t_pl=100348&t_pn=PCW98-7983
    390.00$
    Sell my stock TRD sport rims for at least 400.00$ I'd hope so + 400.00
    TOTAL LIFT COST: 1730.00$
    What do you guys think? I'd really like feedback about the Pro Comp Lift from people using it or have seen it...
    I am still debating whether or not to install this myself or take it to this guy that's TRD certified so no warranties will be voided.
    What do you think a fair install price would be? I would buy all the parts online and take em over to the shop, so lift install, tire and wheel install, alignment, differential drop would be charged labor
    Questions/Comments/Concerns???
  2. Sep 30, 2009 at 6:16 PM
    SantaCruz'n
    SantaCruz'n Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    I got my 3'' Pro Comp lift from truckaddons.com for 390.00 with shipping. You need to call them for that price, for some reason its cheaper when you call. I installed the lift myself in like 7 hours. It was my first time ever doing anything like it. I bought my 285 75 16 from Goodyear Tires for 127.00 a tire. The are really good mud terrains. Everything runs a looks great.
  3. Sep 30, 2009 at 7:41 PM
    FloridaFeMan
    FloridaFeMan Well-Known Member
    Southwest Florida
    '10 FJ Cruiser 4x4, '09 Tacoma TRD DC Sport
    You can do Bili 5100s x 4 and add-a-leaf for same cost and end up with much better shocks than the Pro Comps. Just food for thought. I have seen several pictures of trucks on here lifted with the 3" Pro Comp lift and "they look great" but remember you get what you pay for. Price those Pro Comp shocks out separately and then compare cost to the Bilstein 5100s. Big difference in cost apples to apples. I think the best mid priced suspension lift out there is the OME lift which Toytec website sells for $699.
  4. Sep 30, 2009 at 8:04 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    ^^^What he said about the OME I believe is a good idea. I think you can also get a discount if you contact Neubs, a fellow TW member for a discount at Toytec.
    As for the wheels, I think you can get Cragar Soft 8 wheels. They look comparable to the Rock Crawler ones you want.
    I think you have your money signs backwards too. $440.00 :)
  5. Sep 30, 2009 at 8:16 PM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    honestly you are wasting a lot of money!!!! just get the billy's set at 2.50 and call it a day. you don't need the uca's , or the diff drop. also do yourself a favor and stick with 265/75/16's unless you want to cut your brand new truck up.
  6. Sep 30, 2009 at 8:25 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I wouldnt get the billy's and set em at 2.5 then you will have only a inch of down travel left which will make it useless offroad and it'll suck over speed bumps etc just my .02 but good luck the pro comp looks pretty good and cheap $$ but if you got the bucks go OME
  7. Sep 30, 2009 at 8:35 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I really like my OME stuff under the front of my truck. I was out hittin some rough old logging roads/powerline roads at like 30 today while looking for a way to the top of a mountain by my house. I even managed to catch a little air several times. After a while of it, i stopped for a few min at a dead end i came up to and decided to feel if my shocks were warm because it seemed like I wasnt gettin the dampening I previously was..... The front OMEs were warm, my rear Bilstein 5100s were so hot i couldnt hold my hand on for more than about a second! So, a quality lift with good shocks is very important if youre gonna use it! I highly recommend the OME kit. Also, your wheels would be better with a 5" BS to give a 0 offset. the 4.5" BS will stick them out farther and possibly cause some rubbing in the area of the front mudflap and fender flare.
  8. Oct 1, 2009 at 7:56 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    All of the responses are great info, there are so many damn options out there..
    What about this combo? it would be pretty cheap..
    Front Bilsteins at 2.5", would this be a problem with stock coils? Would I need to put a drop kit in ?
    Rear ADD a Leaf at 1.5"
    Duratrac 265/70/17s on stock TRD sport rims
    would cost just over $1000
  9. Oct 1, 2009 at 10:07 AM
    RelentlessFab
    Eric
    Sparks, NV
    That setup would work fine, though I'd recommend the OME stuff over the billies.
  10. Oct 1, 2009 at 7:05 PM
    FloridaFeMan
    Southwest Florida
    Is your Sport a 4x4 or 2WD? If 2WD, you won't need a differential drop.
  11. Oct 1, 2009 at 7:12 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    its a 4wd :)
    Are you keeping your stock sport rims then? Are you gonna be running a lift with the 265/70/17s, gash was running 2.5" coilover lift, do you think 3" would be too much and make the tires look small?
    Cause as of now I'm thinkin 3" procomp lift, uca's, diff drop, stock trd sport rims and wrap em in a duratrac or km2... cheaper size tire and don't have to buy rims
