Lift, tires & rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ccornforth, Apr 1, 2017.
  1. Apr 1, 2017 at 6:48 PM
    Ccornforth
    Ccornforth [OP] New Member
    2017 Toyota Tacoma off-road
    I'm looking to get a 6" lift. I want to put 35's on I've heard a lot of people say 35's won't fit. I'm looking at 18x12 rim possibly -44 offset. Anyone have this set up? Do the 35's rub?
  2. Apr 1, 2017 at 6:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Assuming you're not yanking our chains for April Fool shenanigans, try using the search feature.
    MyDogJoe likes this.
  3. Apr 1, 2017 at 6:53 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Before the storm starts, welcome to TW.
    Ccornforth[OP] and smitty99 like this.
  4. Apr 1, 2017 at 6:57 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    SocalOC likes this.
  5. Apr 1, 2017 at 6:57 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  6. Apr 2, 2017 at 9:36 AM
    Ccornforth
    Thanks smitty99
  7. Apr 2, 2017 at 9:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Welcome to TW. You'll find that a lot of people on here look down on 6" lifts, for a variety of reasons so we won't be very helpul. They open up a huge can of worms, and in order to do it "properly", you're looking at thousands of dollars. Did you know that in order to install a 6" lift, you have to cut your front cross member (part of your frame) out and have the lift bracket welded in place? It's not easily reversible, so think long and hard before you do this.
    My recommendation would be to spend weeks researching the topic. The search function on here isn't great, so just use Google. Just add "tacomaworld" to the end of your search and it'll bring up better results.
    Ccornforth[OP] likes this.
  8. Apr 2, 2017 at 9:44 AM
    Ccornforth
    Thank you for your help. I appreciate that. I couldn't find what I was looking for in the search form. Was hoping someone who had already done it could give some advise.
  9. Apr 2, 2017 at 9:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    https://www.google.com/webhp?source...6+inch+lift+tacoma+site:www.tacomaworld.com&*
    Here's a start for you.
    To answer your questions about fitting 35's, the answer is yes and no. You can get them to fit, but they'll likely rub over bumps. You'll probably have to do a CMC, but that's not a big deal if you're already cutting your frame for your lift.
    https://www.tacomaworld.com/threads/b-a-m-f-cmc-plates-cab-mount-chop.192527/
    The other expensive thing that I would recommend is re-gearing. 35's are big, heavy tires and you'll definitely notice. You'll put an unnecessary amount of strain on your transmission, and your truck will be really sluggish. A regear to 4.56 from East Coast Gear Supply is $500, plus the cost of installation, which isn't cheap.
    To properly lift the rear to match the front, you'll need a whole new set of leaf springs. Shoving some 4" blocks in the rear is a horrible idea. You'll get really bad axle wrap. A set from Atlas that lifts the rear 4" costs $700, before shipping and taxes.
    Like I said, it can be done, but doing it properly isn't cheap.
    Here's a thread highlighting some of the negatives of the drop bracket style lift.
    https://www.tacomaworld.com/threads/my-2016-tacoma-4x4-trd-4-bds-lift-review-honesty-version.440301/
    DustStorm4x4 likes this.
  10. Apr 2, 2017 at 10:10 AM
    smitty99
    Scottsdale
    You'll need to replace Needle Bearing with a Bushing from ECGS too at some point so you might as well add that to the budget. ~$120 in parts, another ~200-300 in labor if you aren't comfortable pulling tie rods and a cv axle, then removing and replacing the old bearing. Search ECGS and you'll see why.
  11. Apr 2, 2017 at 10:16 AM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
