Lift to fit 35 x 12 wide rims/tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Captain T, Mar 23, 2016.
  1. Mar 23, 2016 at 5:19 PM
    Captain T
    Captain T [OP] Active Member
    Ocala, FL
    2013 Tacoma Double Cab
    4/2 lift 33's 18in Moto Metal Rims Light Bar Mesh Grille
    Hi all,
    Im looking at 20x12 rims with a -44mm offset and i was told that anything over 9 wide wasnt recommended due to fitment issues. I want to run 35s because the rims are so big. So im here to ask two questions.
    • How much lift do I need to make this work?
    • Will I be able to make a U-turn with this set up?(if not its okay as long as my truck looks sexy)
    I will comb through some other threads to see if anyone asked the same question. Thanks all.
  2. Mar 23, 2016 at 5:55 PM
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
  3. Mar 23, 2016 at 6:03 PM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Do you have a 2wd or 4x4?
  4. Mar 23, 2016 at 6:06 PM
    Captain T
    Ocala, FL
    2WD. I work and live on a farm. Dont necissairly need the 35s but more traction 4sure. Should have gotten the 4x4 now that im out here.
  5. Mar 23, 2016 at 6:07 PM
    zth25
    Zach
    In this case 2wd is a good thing. Checkout @SpruceTaco truck. He is running 35s.
  6. Mar 23, 2016 at 6:08 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    ChandlerDOOM and ChadsPride like this.
  7. Mar 23, 2016 at 6:10 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sounds like you're going to want to do a drop bracket lift or a spindle lift since you're a 2wd
    Captain T[QUOTED][OP] likes this.
  8. Mar 23, 2016 at 6:31 PM
    Captain T
    Ocala, FL
    Thanks. If im going to spend the money on rims and tires i want to fit 35s. 33s are an inch bigger than i have now
    Acerwin[QUOTED] likes this.
  9. Mar 23, 2016 at 6:34 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You can do a 3" lift but it requires a lot of work
  10. Mar 23, 2016 at 6:36 PM
    Captain T
    Ocala, FL
    Would it be easier if i went bigger than 3 inches?
  11. Mar 23, 2016 at 6:38 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Spindle for sure!
    zth25 likes this.
  12. Mar 23, 2016 at 6:40 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yes most definitely. I'm running 35's on a ~3" lift but requires a lot of cutting and chopping
    BohlaaH likes this.
  13. Mar 23, 2016 at 6:41 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I would do a spindle lift. I think @sgtnewundies would be a good guy to ask! -44 is massive iffset so you'll need to trim the cab mount and a bit of the fender. Otherwise go nuts. I have a 4x4 and 35s and had 1.25" spacers on and had rubbing. Took them off and problems went away for the most part. I'm not gonna tell you how to build your truck but you may want new rims, or get handy with a grinder!
    Acerwin likes this.
  14. Mar 23, 2016 at 6:42 PM
    zth25
    Zach
    Go with 6-7" of lift. It will look best with the 35s.
  15. Mar 23, 2016 at 6:43 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Just curious why you are wanting a 12" wide wheel.. If you go with a 10" wide wheel it will still give you a nice deep lip and won't stretch the tire as much to give a better ride.
  16. Mar 23, 2016 at 6:55 PM
    Captain T
    Ocala, FL
    Thats a good question. I found them for s good price with tires but im going to look at the 10 wides too. I just like deep lip.
  17. Mar 23, 2016 at 7:00 PM
    BORNWILDGUY
    Rich
    Florida
    I like a wheel with a nice lip as well and have always stuck with a 10" wide w a -24 offset. If you decide to go with a spindle lift you have to remember the spindles push you wheels out a good 3/4 of an inch.
  18. Mar 23, 2016 at 8:36 PM
    Captain T
    Ocala, FL
    Good to know i was unaware of this.
  19. Mar 23, 2016 at 8:37 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    a 20x12 wheel, sounds like you need a lift to Hawaii
    ChandlerDOOM and Sterdog like this.
  20. Mar 23, 2016 at 8:39 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Work on a farm but you're running 20's...
    More power too you I guess. Around here you'd wreck 20's quick on a farm.
