Lift Vibrations????????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaMan, Aug 8, 2015.
  1. Aug 8, 2015 at 3:42 PM
    YotaMan
    YotaMan [OP] TTC #0091
    Austin, Texas
    2020 Tacoma TRD Pro 4x4
    De-Badge,UltraGauge,Westcott Designs fox lift, 18” fuel rebels, Nitto Ridge Grapplers, interior led lights.
    I just installed a full 3'' OME lift kit on my 15' Tacoma last night along with the " Carrier Drop".
    I went to the alignment shop this afternoon and discovered a vibration from 25mph-35mph. After the alignment it did seem to be a little better,so when i returned back home i pulled the "Carrier Drop" back out to see if it let up or got worse. It did seem to get a little better but its still there ( just not as bad ) and driving me nuts! It under acceleration and de acel-- everything looks good, everythings tight and in place? Any help would be much appreciated! Thanks!
  2. Aug 8, 2015 at 3:52 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Does it go away when in 4WD?
  3. Aug 8, 2015 at 3:54 PM
    devkurf
    devkurf Member at Large
    midwest
  4. Aug 8, 2015 at 4:01 PM
    YotaMan
    Austin, Texas
    I havent tried putting it in 4wd yet but i'm going to run out and drive it around the neghborhood real quick to see if it goes away or gets worse.
  5. Aug 8, 2015 at 4:02 PM
    YotaMan
    Austin, Texas
    Neighborhood** Sorry
  6. Aug 8, 2015 at 4:08 PM
    devkurf
    midwest
    Just make sure you only use 4x4 when going straight on pavement. You start making turns on dry pavement locked in and you will have bigger problems.:)
  7. Aug 8, 2015 at 4:22 PM
    YotaMan
    Austin, Texas
    Ok, so i drove it. Put it in 4wd- Vibs still there- same speeds- never went away never got any worse? I cant feel it in the steering wheel nor does it have any when jacked up and spun in the front- I feel it in the seats as if its in the drive shaft or rear end? Any ideas? And again its not bad- just annoying since im pretty OCD about my truck! lol
  8. Aug 8, 2015 at 4:40 PM
    Tacorazy
    Tacorazy Well-Known Member
    Utah
    2014 Barcelona DCLB Sport
    Exactly why I just put a one inch leveling kit on my 2015. My 2008 had a 2.5" spacer lift and I had 3 separate vibrations at 3 separate speeds. I really wanted to go with an OME lift, but in the end I didn't want to chase vibes forever on my brand new, $30K plus truck. I am OCD too. Sorry, didn't make you feel better.
  9. Aug 8, 2015 at 4:42 PM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I have a vibe at take off. IM used to it now.
    agunday21 likes this.
  10. Aug 8, 2015 at 4:51 PM
    YotaMan
    Austin, Texas
    And i'm thinking thats how this is going to turn out.. its so dang annoying- this is my 4th toyota- 3rd 3'' lift - 2.5'' on a 4runner- never had any vibes that i remember- but the other tacoma's had 3'' spacer lift's- this time i went with OME lifting coilovers ( diff drop ) everything to make things correct? Then bam- Vibes! Kinda lost on this one-
  11. Aug 8, 2015 at 4:58 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Did you install axle shims? Some people have fixed vibes doing it:notsure:
  12. Aug 8, 2015 at 5:07 PM
    YotaMan
    Austin, Texas
    No shims- I totally forgot them when i ordered my kit- I'm hoping thats what it is so i can pull the rear-end loose and install them when they come in! Thanks tacomgee
    300AACTaco and tacomgee like this.
  13. Aug 8, 2015 at 5:10 PM
    Alfred
    Alfred
    California
    My vibe seemed better when I removed the carrier bearing drop kit and added shims.
  14. Aug 8, 2015 at 7:00 PM
    YotaMan
    Austin, Texas
    Thats the plan right now, i already removed the carrier drop- ordered the shims- so now its just a waiting game until the shims arrive-And hope and pray the vibes go away!
  15. Aug 8, 2015 at 7:01 PM
    YotaMan
    Austin, Texas
    I dont blame ya, the vibes are getting old Fast!
  16. Aug 8, 2015 at 7:04 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Subd for outcome with shims. Good luck op. This is the only reason I haven't lifted mine yet. I fear the vibes. Would drive me nuts
  17. Aug 8, 2015 at 7:04 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    It's crazy how it happens to some Tacomas and not others, mine only has a very slight vibe while idle, besides that there's nothing, hope you get it sorted out! Sometimes shims in the rear can help, but you have to find the perfect angle
  18. Aug 8, 2015 at 7:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  19. Aug 8, 2015 at 7:19 PM
    YotaMan
    Austin, Texas
  20. Aug 8, 2015 at 7:23 PM
    Alfred
    Alfred
    California
    Just make sure whoever puts your shims on they put them on the right way. I had a shop put them on for me and when I went under my truck to look at them they where on the wrong way
