Lift Vibrations????????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaMan, Aug 8, 2015.
  1. Aug 20, 2015 at 7:10 PM
    #41
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    Thanks, other than the Hurricanes trying to blow me away it is great!!!:rain:
    303tacoma likes this.
  2. Aug 23, 2015 at 8:12 PM
    #42
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    2016 4Runner Trail KDSS
    Just lifted mine 3in and I have peddle vibration on a hard take off. Has your vibes got worse or less?
    I drove about 150 miles with the lift.
  3. Aug 24, 2015 at 12:46 AM
    #43
    2012SilverSport
    Guam
    The vibes don't tend to cure themselves. put it in 4WD and see if it goes away. If it does then it is likely your needle bearing and you should do the ECG bushing. If not then you will likely have to do a carrier bearing rotate/drop, axle degree shim, etc. It will help to verify your drive shaft angles to determine what corrective action to take.
  4. Aug 24, 2015 at 4:26 AM
    #44
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    My truck is a pre-runner so should I start with carrier rating drop?
  5. Aug 25, 2015 at 2:06 PM
    #45
    AJC84
    AJC84 Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    So I brought my truck in to be looked at by lift kit installer. We took it for a drive and they said the vibrations were minor and nothing to worry about and more likely a minor tire balancing issue rather than drive line vibrations. They said if it was a drive line issue I would feel vibrations at all speeds and not just some speed ranges. Can anyone weigh in on this? I am not sure why tire balaning issues would be more pronounced at certain speeds.
    A tire shop recommend putting the truck in neutral at the speed I am getting vibes and see if it stops. If it stops they said its a driveline issue. If it doesn't stop likely a tire balancing issue. Is this line of thought correct? Drive shaft would stop rotating in neutral even while coasting right?
    Also, my dakars or shock started squeaking when braking a low speeds and when I accelerate at low speeds. Haven't been able to pin point it yet. If I grab the edge of bed and rock the truck it squeaks/creaks. Not bad, but fairly annoying since I paid a lot for the OME kit and install. It seems to go away when it rains contrary to what others experienced. Today I took it to a wash bay and lightly sprayed dakars from a distance. After that the squeaking went away, but it seems to come back when the truck dries out.
    What have people found to be the most effective way to get rid of this? I saw several posts about using things like WD40 or penetrating oil on the dakars.
    Was also wondering if others had more success with just getting some good off road use with flexing or if the problem just gets better with time as the suspension breaks in.
    Thanks,
    AC
  6. Aug 25, 2015 at 2:14 PM
    #46
    JCRUZ1724
    JCRUZ1724 Active Member
    Norh NW Fresh
    Level, 31s, and a 4.0
    I have a 3" level kit and 31s mt's and on acceleration and coming to a stop I have vibrations.
  7. Aug 25, 2015 at 4:09 PM
    #47
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  8. Sep 6, 2015 at 10:55 AM
    #48
    Mightytaco06
    Mightytaco06 New Member
    Colorado
    2006 Tacoma 4X4 Shmm
    6" Fabtech lift,
    With a 6" lift, should I try flipping and toting carrier bearing or should I just get a drop kit first?
  9. Sep 6, 2015 at 11:02 AM
    #49
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    This is a new one to me........Not sure what you're saying really?
  10. Sep 9, 2015 at 10:38 PM
    #50
    kietdang28
    kietdang28 Member
    kiet
    Tucson
    Have you solved the vibration?
  11. Oct 25, 2015 at 1:00 PM
    #51
    YotaMan
    YotaMan [OP] TTC #0091
    Austin, Texas
    2020 Tacoma TRD Pro 4x4
    De-Badge,UltraGauge,Westcott Designs fox lift, 18” fuel rebels, Nitto Ridge Grapplers, interior led lights.
    Finally got around the installing the axle shims today- I have a URGENT question- skinny side of the shin to the front? And since I have 1.5" lifting blocks does the shim go under the block ( between axle pad and block) or on top of the block ( between block and leaf springs) ???? Or does it even matter? Any help would be greatly appreciated!!!!!
  12. Oct 25, 2015 at 4:48 PM
    #52
    YotaMan
    Austin, Texas
    Ok, got the shims installed today. Flipped the carrier bearing back to the OE position. Drove the truck, and not a single vibration! Those who have vibs- grab some axle shims!
  13. Oct 25, 2015 at 5:08 PM
    #53
    RubiconTX
    RubiconTX Member
    Austin TX
    14 Tacoma 4x4
    Just waiting for my OME lift to get delivered. This information will come in handy.
    Thanks,
  14. Oct 25, 2015 at 5:55 PM
    #54
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    For all of you that flipped your carrier bearing... how?? I just jumped under my truck to see if I could flip it, pulled off to two bolts that hold it to the frame, rotated and no love. The carrier bearing width upside down is too wide for the mount that it sits on upside down. Is my truck just an oddball?
    I've had vibes forever and just kind of ignored it but now that I've got some smooth riding KO2's, I wanna get these vibes taken care of.
  15. Dec 3, 2015 at 8:26 PM
    #55
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Just shove it in.
    Or shim it with some washers after flipping it.
    Mine was too high after rotating. I shimmed it down 3/4 inch. It's still a bit higher than what it was un-shimmed before flipping.
    Seems to have smoothed out all but the launch shudder at 5mph.
  16. Dec 4, 2015 at 4:27 AM
    #56
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Not trying to be a dick but remove your lift and I guarantee you the vibrations will go away. I could never understand why someone would take a perfectly good smooth running truck and mess it up with a lift for the sakes of "getting the look". I perfectly understand when someone needs the clearance for off road use but most don't use there vehicle that way. Some even lift they're prerunners which I'll never understand. I guess the "big truck feel" is more important and people will just live with worse gas mileage, vibrations, poor handling from the high centre of gravity, and tire wear.
    Mavrick likes this.
  17. Dec 4, 2015 at 9:44 AM
    #57
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    It wasn't from the lift. I had vibrations after I took my truck off of some sweet jumps.
    pidgeball likes this.
  18. Dec 4, 2015 at 10:12 AM
    #58
    evan
    evan Well-Known Member
    SK, Canada
    Good to know. Where did you get the shims?
  19. Dec 4, 2015 at 1:43 PM
    #59
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    kietdang28 and PVT Pablo[QUOTED] like this.
  20. Jan 2, 2016 at 12:53 AM
    #60
    YotaMan
    Austin, Texas
    If I remember right I think I got them from wheelers off road. 3 degree shims
