Lift Vibrations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fortis44, Aug 28, 2018.
  1. Aug 28, 2018 at 6:27 AM
    fortis44
    fortis44 [OP] Well-Known Member
    Colorado Springs, CO
    2016 TRDOR DCSB Black
    OME Nitros, 888s, HD Dakars, 285s
    Hi all,
    I've been on my 2.5" OME Nitrocharger lift for a couple of months now, and am noticing vibration at only VERY low speeds, roughly from 0-15 mph. I understand that most people fix vibration issues with the ECGS bushing install, but I've never seen the said vibration behavior explained, so I'm unsure if this fix would actually alleviate the issue.
    For those who did the ECGS bushing replacement, did you previously have vibrations at low speed, and they disappeared after install?
  2. Aug 28, 2018 at 6:49 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Engage your 4Hi (then drive), if the vibrations go away its probably not the needle bearing. So no ECGS mod needed. Next vibration culprit is the drive shaft, common fixes are angle shims under the leaf springs and/or carrier bearing spacers.
    Are the vibrations coming from the fron or rear?
  3. Aug 28, 2018 at 6:50 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    No, if the vibe goes away in 4hi it is the needle bearing and he needs the bushing.
  4. Aug 28, 2018 at 7:01 AM
    fortis44
    The vibrations are definitely coming from the front of the vehicle. With that said, Discount Tire has been having a really tough time balancing my Wildpeaks, so that might be adding to the vibrations. Even when the tires are perfectly balanced though, I'm still getting vibes.
  5. Aug 28, 2018 at 7:06 AM
    rnish
    Tacoma 2nd gen
    I stand corrected.
  6. Aug 28, 2018 at 7:06 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    With over a 2" lift you should change to the ECGS bushing anyhow, it can only help. This goes all the way back to 2005 and the 2nd gens.
  7. Aug 28, 2018 at 7:09 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    At such a low speed, I wouldn't think the tires would make much vibration if they were unbalanced? - thinking out loud. I know I have some steering wheel vibrations at high speed with my wildpeaks...I'm pretty sure I have a bad tire still but don't feel like going back to Discount to figure it out/fight for a replacement, ha.
    Try engaging 4x4 like others have said and see if the vibrations go away.
  8. Aug 28, 2018 at 7:11 AM
    fortis44
    And that's what I thought also, but after leaving Discount this weekend the vibrations got significantly worse. I'll give the 4x4 a shot and write back later. Hoping this is a quick and easy fix
  9. Aug 28, 2018 at 7:21 AM
    squiggy
    squiggy Well-Known Member
    Vermont
    2019 Tacoma 4 door long bed TRD OFF ROAD
    none yet
    I installed the OME suspension lift on my 2012 Tacoma. I get a vibration when going about 5 MPH when I start to accelerate. The lift came with a shim for the driveshaft but still get the vibration with or without the shim. Will replacing the needle bearing and the ECGS bushing fix this problem?
  10. Aug 28, 2018 at 7:38 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    As mentioned above, does the vibration go away in 4hi
  11. Aug 28, 2018 at 8:58 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Keep us posted OP.
  12. Aug 28, 2018 at 8:59 AM
    fortis44
    Will do. Regardless, I think I need to do the upgrade anyways. $200 for peace of mind goes a long way.
  13. Aug 28, 2018 at 9:17 AM
    Grossomotto
    2017 4WDV6LB6MT
    It's a matter of time before the OE needle bearing goes out with a 2-3"+ lift.
    Keep in mind, just because it's a vibration, doesn't mean it's just one. Two could be happening at the same time, or even three including drive line issues, etc.
    Often members get their wheels balanced and say they still have a vibration. It's really hard for people to think that two things could be happening at once. We often think it's just one issue.
  14. Aug 28, 2018 at 9:23 AM
    fortis44
    Agreed with both of you, and the reason for asking the question was to avoid doing one mod, then finding that it didn't achieve the effect I want. I definitely don't want to dive into a black hole on this one.
  15. Aug 28, 2018 at 9:24 AM
    OrangeJulius
    OrangeJulius Well-Known Member
    2017 Orange TRD off-road WIP
    If the issue started immediately after the lift, it's not the needle bearing. It's drive shaft angles. I had an issue at 20mph and I did the CB drop and it didn't fix it. I added washers and it only changed when the vibration occurred. I finally got 2.5 degree shims and with the drop still in place the vibes are gone.
    ControlAltDelete likes this.
  16. Aug 28, 2018 at 9:27 AM
    Grossomotto
    2017 4WDV6LB6MT
    Agreed, often times 4500lb 4WD trucks with bigger than OE tires just vibrate no matter what.
    There's too many members that think they'll lift their truck 3"+, bigger tires, longer travel suspension and it will ride flawless at 70mph on the freeway. I'm aware that's not the case with the OP, but yeah people can chase issues spending shit tons of money that amounts to nothing.
    If you can change the bushing yourself, it's less than $100. I ran into some issues because I'm a dumbass and it worked out, but I learned a lot.
  17. Aug 28, 2018 at 9:29 AM
    fortis44
    Yeah, I fully expected things to not feel like stock or to even have thunking, clunking, and small vibrations every once and awhile. These vibrations at low speeds have me worried about city driving, and ultimately leading to a failure due to constant start-stop.
    If it helps any, after a week of offroading in Moab, the vibrations got worse.
  18. Aug 28, 2018 at 9:36 AM
    Grossomotto
    2017 4WDV6LB6MT
    Does the vibration go away in 4WD?
  19. Aug 28, 2018 at 10:16 AM
    fortis44
    I haven't tested in yet. I'll give it a try heading home from work.
  20. Aug 28, 2018 at 2:04 PM
    squiggy
    Vermont
    none yet
    I just test drove my truck in 4HI and the vibration is not there. I did have the shim installed but I took it off thinking that was causing the vibration.
