Lift wanted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota_life3339, Dec 15, 2015.
  1. Dec 15, 2015 at 3:58 PM
    Yota_life3339
    Yota_life3339 [OP] New Member
    Braydon
    2005 white tacoma 5 lug
    Hid headlight conversion, plasti dipped front bumper, black wheels, k&k cold air intake, de-badge, led reverse license plate and interior lights.
    I have 255 70 15 general grabber at2 and I'm worried about clearance. I have 235-75-15 on now I have searched a lot for lifts and haven't found much for 5 lugs but a sst ready lift has any installed this? Would also like new wheels not sure what to get please suggest options and fitments!
  2. Dec 24, 2015 at 9:44 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    So difference in diameter is 2.2 inches. (adds 1.1 inch on each "side") I do not think that it will rub at all. I think that our trucks have at least 6 inches wheel well clearance.
    Why you think that you need lift? I was thinking of buying larger tires when oem are bold.
  3. Dec 25, 2015 at 6:15 AM
    Pigpen
    Dan
    Northwest Montana
    Do some reading in the 5 lug threads. I have an extra lug, so that's the best advice I can give.
