lift with exhaust
Discussion in 'Suspension' started by JK4, Jun 26, 2009.
  1. Jun 26, 2009 at 9:13 PM
    JK4
    JK4 [OP] Member
    09 PreRunner Double Cab
    i am wondering...
    if you have straight pipe dual tips exhaust and you get a suspension lift of any kind.
    does it make the exhaust look bad?
    does your truck move up and the exhaust not move or does it all move up (truck and exhaust)
    i have seen some like that, where the exhaust stays at the same level and then the truck is lifted higher. i think it looks bad.
    is it only body lifts where this occurs?
  2. Jun 26, 2009 at 9:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its mostly with body lifts that everything stays where its at......with a regular suspension lift, depending on where the exhaust is mounted to the frame/hangers, it will stay where its at.
