Lift with VSC answer.....
Discussion in 'Suspension' started by TRDnAZ, Jun 16, 2009.
  1. May 13, 2012 at 10:21 PM
    #181
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  2. May 13, 2012 at 10:57 PM
    #182
    Desert Rat
    Desert Rat Well-Known Member
    Monterey, California
    2012 Tacoma DCSB TRD Off Road Double Cab
    3" OME lift, Avid lightbar and sliders, PIAA 525s, custom Baja Rack, SnugTop with Windoors, PopnLock tailgate, power moonroof, ARB awning, Pioneer AVIC-Z140BH, Alpine amp, Pioneers speakers, custom subwoofer.
    I was thinking along the lines of "minimum clearance" as well. That thread is hugely helpful.
    So maybe it *is* worth it. Still not really sure what parts to get if I order a set of 5100s (utilizing the factory coil overs). Trying to stay somewhat stock with the least potential for added wear to the factory components. Guess I'll give Toytec a ring again tomorrow...
  3. May 14, 2012 at 3:17 AM
    #183
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    :popcorn: I want to see if an answer is found to the VSC issue. I see alot of good ideas here about what may cause it,but only one that seems to be a definitive fix( although not all who have the issue had it work for them. ) It's an odd one for sure !
  4. May 14, 2012 at 7:57 AM
    #184
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Desert Rat, why don't you start your own thread. That way we leave this thread for the people having VSC issues.
    Just a suggestion. You'll be able to follow the posts addressed to you easier.
    Plus, people may want to follow your build. From what I read, I do :)
  5. May 14, 2012 at 9:08 AM
    #185
    Desert Rat
    Well, I got involved in this thread a few months ago because I wanted to do a 2012 build that specifically avoided VSC issues, and the discussion here and elsewhere has been very helpful in understanding what's involved. What I have found is that there is no "right" answer, and results vary, even with identical setups. Alignment and zero-point recalibration are critical, along with offset.
    The most relevant, useful VSC info that I can directly report is that the larger tires on stock rims caused no rubbing and no nanny alarms. Because there is limited upside (pun intended) to a moderate suspension lift retaining my new 265/75R16s I might not do anything further; will report back if I do.
    While I'm not compelled to start a thread for my new vehicle (and almost all my participation in TacomaWorld has been this thread), I will post a picture here once it's finished and 40 miles from asphalt in Utah at the beginning of June; hopefully an image showcasing adequate "minimum clearance" on stock suspension.
    Thanks for the help everyone.
  6. May 15, 2012 at 5:17 AM
    #186
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    the zero point is basically what a hunter alingment codelink box does, thats what I did to my truck when I aligned it a just tires
  7. May 29, 2012 at 5:15 PM
    #187
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Does the beeping always happen when it engages? i have a similar issue but I get no beeping or pulsating. just one pulse with no beep
  8. May 29, 2012 at 5:33 PM
    #188
    OZ-T
    Peter North
    British Columbia
    I read your thread and was going to ask you if you had a beeping
  9. Jun 26, 2012 at 11:53 PM
    #189
    Desert Rat
  10. Jun 30, 2012 at 10:20 AM
    #190
    tacoTRD12
    tacoTRD12 Member
    Tim
    Nor Cal
    White 2012 DBL Cab Lng Bed, 4X4 TRD Sport
    BDS 6" Lift, Camburg UCA, nFab side steps, Extang Tonneau, Black badging
    Hi guys, I have a 2012 with Toytec 3" lift, 18" wheels and 275/70/18 tires. My vsc kicks in on the hwy on ramps. Called the local dealer in Dublin,Ca who actually lift and sell Tacoma's. The service tech told me they deal with this on their lifted vehicles. They said you can't adjust the vsc on a 2012. Does any know if that is fact?
    They install the Superlift's TruSpeed to resolve the vsc issue. Has any one tried to us this?
  11. Jun 30, 2012 at 11:07 AM
    #191
    OZ-T
    Peter North
    British Columbia
    The VSC can't be adjusted , but should be recalibrated after lifting , see the pdf in the first post of this thread
    First I've heard of the TruSpeed
  12. Jun 30, 2012 at 11:15 AM
    #192
    Desert Rat
    The two dealers I spoke with said they can do the zero-point recalibration (along with shimming sensors if necessary) but they have not been able to fully resolve VSC problems with *any* of the trucks they've lifted (which invariably have larger wheels/tires). My guess is because you are running 18" wheels yours may be difficult to resolve, but you may be able to minimize it somewhat (and of course turn off every time you start the vehicle) but you may be stuck with it.
    What your dealer mentioned would some to be a novel solution: http://www.superlift.com/accessories/truspeed.asp
  13. Jul 1, 2012 at 7:32 AM
    #193
    CCFBERG
    CCFBERG The Shocker and Me Tall Dark TACO
    Shawn
    LRAFB Arkansas
    2010 TRD 4x4 SR5 DBL cab
    Kenwood 516 DD head unit, Kenwood 12" sub, Kenwood 1800W amp, Brighter reverse light mod, 2nd Air filter ripped out, Tailgate anti-theft. Fog light anytime. Rearview mirror display in HU mod. JBA shorty headers & Catback. K&N Filter. Smittybilt Nerf Steps. Smittybilt M1 Grille. Pro Comp stage II, 6" Lift. 12V Bed PWR. LED interior lighting
    I run 18's with 6" of lift. After the alignment and recal...there's been zero issues. It can be done.
  14. Jul 1, 2012 at 9:49 AM
    #194
    Desert Rat
    Yes, Toyota told me 6" lifts cause less VSC problems.
  15. Jul 13, 2012 at 8:17 AM
    #195
    tacoTRD12
    tacoTRD12 Member
    Tim
    Nor Cal
    Had my dealer do the Zero calibration from the pdf suggested and waste of money. Didn't help at all. Abs still kicks in at higher speeds when using curved ramps to freeways :(
  16. Jul 13, 2012 at 8:29 AM
    #196
    GP3
    California
    4X4 TRD Off Road
    Stock wheels?
  17. Jul 13, 2012 at 10:19 AM
    #197
    OZ-T
    Peter North
    British Columbia
    Why did you pay ? Mine was covered under warranty .
  18. Jul 14, 2012 at 9:11 AM
    #198
    tacoTRD12
    tacoTRD12 Member
    Tim
    Nor Cal
    Not under warranty when you modify wheels, suspension and larger tires.
  19. Jul 14, 2012 at 12:33 PM
    #199
    OZ-T
    Peter North
    British Columbia
    Was for me , your dealer sucks
  20. Jul 14, 2012 at 12:50 PM
    #200
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Your dealer is exceptionally helpful and understanding.
    I've never had a dealer, toyota or otherwise, bend over backward like that.
