Lift with VSC answer.....
Discussion in 'Suspension' started by TRDnAZ, Jun 16, 2009.
  1. May 14, 2013 at 7:25 PM
    #221
    09sr5
    09sr5 gonna be a long ride
    East Tennessee
    2009 sr5 2.7 4x4 AC
    265/75 AT3's on stock wheels. 5100's@1.75". Trail Gear sliders. Toytec AAL
    Same thing happened to me.
  2. Jun 10, 2013 at 9:15 PM
    #222
    mendo girl
    mendo girl New Member
    Alena
    Nor Cal
    2011 Toyota Tacoma TRD Sport 4X4
    2-3 inch Revtec lift by Les Schwab, 265-75-18 after market rims and mud tires, Banks Exhaust, AFE Cold Air Intake, Throttle Body Spacer, Air Sensor Chip.
    2-3 inch Revtec lift by Les Schwab, 265-75-18 after market rims and mud tires, I am having the same issues as most of you, very frustrating and scary!
  3. Jul 8, 2013 at 2:55 PM
    #223
    dcurtis
    dcurtis Member
    Don
    Chico, Ca
    06 TRD
    5100 Billy's eibach springs
    I think there are two different things going on here. I think some people have lights on after the truck is lifted and other are having the VSC kick in suddenly in the middle of a corner without the lights being a problem from the start.
    Mine does the latter. I have a 2006 dbl which has VSC but no switch on the dash to turn it off. I put a 5100's on all 4 corners with eibach springs in the front set to .85 and firestone air bags in the rear which I run at 5-8 lbs. when not loaded. I have stock 16 inch rims with 265/75/16 bfg rugged terrain tires.
    This last weekend I had the truck loaded down with camping gear, and family with 20 lbs. in the air bags on a twisty road and the VSC kicked in hard and suddenly in the middle of a corner. Scared the hell out of me. It did this twice more on the way up and three times on the way back. The last time I had a car tailgating me because I had slowed down trying not to have the thing go off again. It went off anyways and I was nearly rearended. I am going to try the recalibration but this has put doubt in my mind with this truck.
    I have noticed that my stearing wheel was not perfectly straight after having the truck aligned, and I will try to get that fixed as well. Right now I feel my best option is to wire in a kill switch for the VSC and be done with it.
  4. Aug 8, 2013 at 3:41 PM
    #224
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
  5. Aug 8, 2013 at 4:49 PM
    #225
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. Mar 5, 2014 at 2:54 PM
    #226
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    sub for ref.
  7. Jun 17, 2014 at 6:38 PM
    #227
    sdtag
    sdtag Well-Known Member
    So Cal
    2015 TRD Sport DC LB
    lifted 2", snug top, tube steps
    ok this may sound silly - bear with me...
    Pressing the vsc button for 3 seconds at start up turns it off?
    What about adding an off delay timer under the dash? Every time I start my truck the timer will kick in for 3 seconds, shutting off the vsc. Think this will work?
  8. Jun 17, 2014 at 8:41 PM
    #228
    OZ-T
    Peter North
    British Columbia
    At a stop , press anc hold the VSC button for 3-5 seconds , AUTO LSD and VSC OFF will illuminate on the dash , keep holding the button till AUTO LSD goes out leaving only VSC OFF illuminated
  9. Jun 27, 2014 at 5:15 AM
    #229
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    I can't read through all 200+ posts here but
    I've got a '13
    And after screwing around all weekend I hit something & the VSC light came on, disabled the VSC system and won't turn off.
    It's in for an alignment now- do you think a tire shop or the mechanic next door could do the instructions on the PDF from page 1?
    And does this calibrate anything else but the yaw sensor? (Speedometer for larger tires )
    Thanks guys
  10. Jul 28, 2014 at 6:32 PM
    #230
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    For future reference, and since I haven't trouble-shot this yet, my VSC slip light comes on about 20 seconds into driving in a straight line. It first happened during this last front wheel alignment, after changing an lca and having the shop hand-align the wheels.
  11. Aug 10, 2014 at 5:35 PM
    #231
    TRD 13
    TRD 13 Active Member
    Spencer, WV
    2013 TRD double cab short box 6 speed
    6" rough country lift, 35" mud terrains
    OK, I just stumbled on this thread while trying to figure out what the hell is wrong with my 2013 TRD sport. I had it lifted 3 weeks ago. 6" rough country, 35x12.5x17's on 878 Helo's. first two weeks, no issues other than my steering wheel is slightly off center (1/4" to right). Monday I had my front right wheel lock up at 40 mph in a left hand curve. I couldn't make it do it again and shook I off as a "freak thing". Yesterday it happened 4 times in 30 miles on a crooked paved road. Its always the outside wheel in a curve. No beeping, no lights. That doesn't sound like VSC based on what Im reading here???
  12. Aug 10, 2014 at 5:46 PM
    #232
    OZ-T
    Peter North
    British Columbia
    If there is no beep it's not a VSC / Traction Control engagement , are you sure your tires aren't rubbing ?
  13. Aug 10, 2014 at 6:05 PM
    #233
    TRD 13
    Spencer, WV
    Absolutely positive. The brake pedal surges like abs is activated when this happens and I get pulled in the direction of the wheel that's locking up.
  14. Aug 10, 2014 at 6:18 PM
    #234
    OZ-T
    Peter North
    British Columbia
    That's a VSC / Traction Control engagement then , are you certain there was no beeping ? Maybe you had the radio on ?
  15. Aug 10, 2014 at 6:27 PM
    #235
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    I had the same issues ,VSC would kick in around corners and pull me into the other lane .Asked dealership about a recalibration got the deer in headlights stare back at me.Truck was not safe.So I pulled the VSC andABS fuse(#2 I think) put some black tape over the dash lights and bingo no more issues mind you I don't have VSC and ABS but it is a lifted 4x4
  16. Aug 10, 2014 at 6:37 PM
    #236
    TRD 13
    Spencer, WV
    No beeping. When it happened 4 times yesterday I turned the radio off and killed all the other sounds in the truck so I could get a good idea what was going on. No dash lights, no beeping, just surging brake on 1 wheel at a time. Scary shit!
  17. Aug 10, 2014 at 6:41 PM
    #237
    OZ-T
    Peter North
    British Columbia
    Interesting , I wonder if the beep is disabled in the later models
  18. Aug 10, 2014 at 6:43 PM
    #238
    TRD 13
    Spencer, WV
    Im guessing that the abs fuse will be my resolution as well. Im gonna call the dealership tomorrow, and the off road shop that dismy lift, wheels and tires. Im guessing the dealership tells me that its my fault for lifting it, and the off road shop will likely tell me something similar.
  19. Aug 10, 2014 at 6:45 PM
    #239
    OZ-T
    Peter North
    British Columbia
    Print ot the pdf from the first post and take it with you
  20. Aug 11, 2014 at 7:35 AM
    #240
    TRD 13
    Spencer, WV
    I talked to the rep from the off road shop this morning. H emailed me after he made some phone calls. Here is his response:
    "I just talked to Rough Country. They have only had it happen a few times. They said they have seen the alignment, stretched abs line, or the abs sensor might not be seated in all the way. I have not had this happen before".
