Lift with VSC answer.....
Discussion in 'Suspension' started by TRDnAZ, Jun 16, 2009.
  1. Aug 9, 2010 at 1:44 PM
    forrest108
    forrest108 Member
    2010 LB 4x4 Silver
    ICON front COs (+2") and rear shocks, upsized Duratrac tires.
    Went to dealership for recalibration, had to give them the pdf instructions.
    This has made no difference. VSC still goes off around corners with some rough asphalt. Nothing safe about it.
    Dealership has had trouble controlling the VSC on a lifted truck they sold.
    IF you find out anything like a simple disconnect please post.
    Thank you,
  2. Aug 9, 2010 at 5:41 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    This doesnt make sense to me. How would lifting the truck affect the yaw-rate sensor? B/C really the yaw rate sensor just tells if you fishtailing type of situation. So how does lifting the truck affect this? This is really the only thread that i see of this type...how come so many other people arent having problems?
  3. Aug 9, 2010 at 6:44 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    its the lift... i have 3 inch lift and my vsc is more touchy and im on stock tires. some lifts have more effect than others, depending on the stiffness of the ride.
    This is why procomp makes two lifts. on vsc compatible and one that isnt
  4. Aug 9, 2010 at 7:31 PM
    TRDKenE
    Kenny
    Richmond, Virginia
    well that helped me...I will go with the softer coil springs then
  5. Aug 9, 2010 at 7:36 PM
    Yoytoda
    Roland
    completely stock
    i think stiffer springs will minimize body roll and reduce vsc. IDK but its frustrating. When i install a locker im going to disable the vsc and abs.
    I hate abs especially in snow. itll be nice to screw around and not worry about vsc "protecting" you too
  6. Aug 24, 2010 at 11:03 PM
    DaveSmith
    DaveSmith Active Member
    Dave
    Maine
    2010 Tacoma TRD Offroad
    Take a look at this post from TundraSolutions (bottom of page). It looks like shimming up the back of the yaw rate sensor along with resetting the zero points for yaw and deceleration is the fix.
    It will take me a week before I can try this out but I will post info asap. If anyone beats me to it please post results.
    Anyone know where the yaw rate sensor is on the 2010's?
  7. Aug 24, 2010 at 11:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Cool info Dave . I hope this translates to our Tacomas . :D
  8. Aug 27, 2010 at 9:55 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Thanks for digging this up. Looking forward to hearing about the results.
  9. Jan 17, 2011 at 7:09 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    anybody ever try applying this solution to the tacoma?
  10. Apr 9, 2011 at 3:29 PM
    CCFBERG
    CCFBERG The Shocker and Me Tall Dark TACO
    Shawn
    LRAFB Arkansas
    2010 TRD 4x4 SR5 DBL cab
    Kenwood 516 DD head unit, Kenwood 12" sub, Kenwood 1800W amp, Brighter reverse light mod, 2nd Air filter ripped out, Tailgate anti-theft. Fog light anytime. Rearview mirror display in HU mod. JBA shorty headers & Catback. K&N Filter. Smittybilt Nerf Steps. Smittybilt M1 Grille. Pro Comp stage II, 6" Lift. 12V Bed PWR. LED interior lighting
    Im currious also because Ill be installing lift and tires very soon and Im VSC. Maybe they tried it and didnt make it back:confused:
  11. Apr 9, 2011 at 9:09 PM
    Yoytoda
    Roland
    completely stock
    have 2010 lifted 3" all around, no vsc issues...
  12. Apr 10, 2011 at 1:36 AM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    billstein 5100's at 2.5" and 1/4" top plate spacer which makes it 3" on driver side and 2" aal in rear. i was worried before the lift and i'm happy i haven't had any problems.
  13. Apr 11, 2011 at 7:00 AM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I have this issue on my truck...I seem to only have the issue on certain angled turns, and at any speed rate at above 30mph...I started driving more slow around certain turns that I think will set it off, and im ok....but my truck still has this issue and its very annoying to feel like im driving on eggshells in corners. I am on a 3" lift with 285 tires. For the kits like the procomp 6" for VSC...does this stop the vsc from going off? also, for the thing mentioned above about holding the VSC for 3 seconds...does this help at all?
  14. Apr 11, 2011 at 7:16 AM
    OZ-T
    Peter North
    British Columbia
    Did you get your skid control ECU zeroed after your lift ?
  15. Apr 11, 2011 at 8:46 AM
    #35
    Yoytoda
    Roland
    completely stock
    do you have issues with your vsc kicking in? Im lifted 3" all around and make the drive up and down the mountains all the time, no issue whatsoever...
    This whole thing is making me wonder if it has more to do with 33"+ tires... Like i said im lifted 3" with 32" tires and no issue but know of people with 33s that have issues... :notsure:
  16. Apr 24, 2011 at 4:37 PM
    #36
    larry2375
    honolulu
    vsc kicked in while taking the twisted on ramp to the freeway around 40mph. i first felt the brakes pulsing. went around three more times on the same on ramp to check what conditions would make the vsc kick in. seems like it would kick in at sharp turns going 40mph. i have 5100's set at 2.5" with 265/70 17" tires. getting 285/70 tires in two weeks, so i'll test it out again. :(
  17. Apr 24, 2011 at 5:27 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Have you had the skid control ecu re-calibrated after your lift install ?
  18. Apr 24, 2011 at 5:47 PM
    #38
    larry2375
    honolulu
    no, seems from reading threads, it may not help, and i don't want to jump the wrong pins.
  19. Apr 24, 2011 at 6:28 PM
    #39
    OZ-T
    Peter North
    British Columbia
    I got it done @ the dealership .
  20. Apr 24, 2011 at 6:59 PM
    #40
    larry2375
    honolulu
    were you experiencing the vsc kicking in and did the calibration work for you?
