Lift without diff drop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by New2metaco, Nov 21, 2017.
  1. Nov 21, 2017 at 8:24 AM
    New2metaco
    New2metaco [OP] New Member
    2007 4 X 4 TRD SR5
    Hello everyone, I’m fresh to the Tacoma scene. About a week ago I bought an ‘07 and love it. I just need a little more height for a little more tire. Not much. How high could I go without doing the diff drop an skid plate drop. I’m just thinking 2” front and back. Thanks in advance.
  2. Nov 21, 2017 at 8:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    You'll get a pile of answers here, most of which will be correct. And confusing.
    Just call Marie @HeadStrong Off-Road and talk though your goals. She'll recommend the right stuff to meet those.
    Keep in mind that wheel fitment has more to do with tire size/rubbing/etc than 'lift' does. So, do you really even need lift, like for some other purpose?
  3. Nov 21, 2017 at 8:31 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Should be good with that height. I wanna say many start worrying about cv angles at 2.5 inches and higher. I had mine at 2.25 inches before I went LT and had zero issues and didn’t even get ucas before swapping the front up.
  4. Nov 21, 2017 at 9:18 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    Awww come on. We need another wonderful debate about to diff drop or not, right before Thanksgiving... don't we? We need SOMETHING. I haven't seen a "What lift should I get?" thread in awhile.
    20RustyTaco06, EatSleepTacos and Aw9d like this.
  5. Nov 21, 2017 at 11:05 AM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2011 D-CAB Black TRD Sport, JBL with Sat
    leveling kit, Cooper 255/80R17 tires on 4Runner rims, Leer cap, Ovtuned (not yet working), K&N filter, TRD catback, Riderite air bags
    I can tell you first hand.... I put a 2.5 spacer lift on the front and a 1.5 block + airbag (2.5 total) on the back. I have no diff drop and I have no vibration. I am going on two and a half years with the lift. I will give you some advice... if you are doing lift + tires or lift + tires/wheels I would consider doing them in stages. do the lift do an alignment then drive it for a few days.... if you are happy, add the tires/wheels. I did it all at once and it took a month to figure out my issues (all were caused by a balancing issue).
  6. Nov 21, 2017 at 2:54 PM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    i have had 2 2nd gen tacos with ~3" lift............. one with diff drop, and one without..... honestly don't think it matters....
  7. Nov 21, 2017 at 5:48 PM
    New2metaco
    2007 4 X 4 TRD SR5
    That’s great advice I appreciate it all. I’m really just wanting a little more height and slightly better stance. I like the truck as is but it just needs a little something extra. While we’re on the subject, does anyone have recommendations of a tire that looks aggressive but rides quiet? I’m all about appearances, A real poser. But I’m honest.
  8. Nov 21, 2017 at 6:52 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Cooper ST Maxx, nitto ridge grappler, Toyo rt, duratracs, all are hybrid all terrain, search and choose the one you like best.
  9. Nov 21, 2017 at 6:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    General grabber AT2s are aggressive and inexpensive-ish, or you could go all out and get the KO2s and fully embrace the poser look.
    PintSize likes this.
  10. Nov 21, 2017 at 6:59 PM
    medic2230
    Murph
    Bama! Roll Tide
    You can go 3" on a 2nd gen and don't need a diff drop. All the diff drop does on a 2nd gen is rotate the diff. You're not going to get enough out of it to matter. Center bearing drop yes but don't bother with the diff drop on a 2nd gen. You don't need to worry about anything with the skid plate on dropping it. You want more clearance not less.
    MuddyJackson and t.hornstra like this.
  11. Nov 22, 2017 at 3:39 AM
    New2metaco
    2007 4 X 4 TRD SR5
    Thanks guys I really appreciate it. I’ve been on a few message board type sites for motorcycles but this one is the best. Thank you
  12. Nov 22, 2017 at 10:25 AM
    Captainskidmark
    Northern Illinois
    Always been a fan of BFG A/T, not too bad on noise.... But for some reason this time around I went with cooper discoverer stt pros and they were a bit noisey... til I installed RAAMmat...
