Lift without replacing leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by GravyTrain180, Dec 4, 2022.
  1. Dec 4, 2022 at 6:07 AM
    GravyTrain180
    GravyTrain180 [OP] Member
    Grayson
    2004 tacoma TRD double cab
    None yet
    How far can a lift my 2004 taco without replacing the leaf springs?
    I just bought it and I need to replace the rear end due to rust (this dude must have owned a boat) and my rear shocks are pretty rusted and need replacement. I figure while I’m taking the whole read end out I mine as well lift it a couple inches too. I don’t really want to lift more than 2 or 3 inches and I’m wondering if I can do that or maybe even a 1” lift without having to replace my leaf springs.
  2. Dec 4, 2022 at 6:31 AM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Welcome to Tacomaworld! You have a lot to learn my friend. The good news is you’ve come to the right place to learn it. Use the search bar, it’s going to be your best friend when asking a question, I don’t think there’s anything that hasn’t already been discussed a billion times on here.
    Now to help you with your concern, rust in the back of these trucks are very common and widespread, they even recalled the frames at one point. That should have been the first thing you inspected when you found the truck for sale. You may need to dig deeper into your rust issue before you do anything else. The frame will break right behind the cab.
    It’s your truck though, so if you just want a quick little lift in the rear on the cheap, I’d go with longer shackles.
  3. Dec 4, 2022 at 6:49 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
  4. Dec 4, 2022 at 7:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If your rear shocks have rusted out (which means it has to be really bad back there), why wouldn't you want to replace your leaf pack?
  5. Dec 4, 2022 at 7:38 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Not just for the OP but many people do not know what rust can do to a vehicle. Your frame can rust so bad that it can shear into pieces. For example frames can rust through so can shock mounts, cross members, steering component mounts.
    If you are going to buy a used vehicle you owe it to yourself to go up under the vehicle with a flashlight and a Phillips head screw driver or ice pick and start poking around. If you make a hole in the frame just pass up buying the vehicle.
  6. Dec 4, 2022 at 11:37 AM
    GravyTrain180
    Grayson
    None yet
    My leafs are in near perfect condition, must have been replace before
  7. Dec 4, 2022 at 11:39 AM
    GravyTrain180
    Grayson
    None yet
    I appreciate everyone’s concern for the rust, but I am well past inspecting rust. My frame is perfect, my leafs are perfect, my front is not rusted enough anywhere to warrant replacement. I just want to know if I can lift my taco without changing the leaf springs
  8. Dec 4, 2022 at 10:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    you can do a "Cheap" lift with blocks, but most here on TW don't recommend it.
