Lift
Discussion in 'Technical Chat' started by SPORT, Jul 1, 2010.
  1. Jul 1, 2010 at 5:29 AM
    SPORT
    SPORT [OP] Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    Greetings all,
    New here, and just started 'searching' for this question, but also wanted to expedite my query by asking too.
    Just bought a '10 Tacoma DC TRD Off Road 4x4 short bed and am wanting to provide a 1-3" lift (probably only 2").
    I've read some polls regarding this and it's a general understanding that block lifts are not preferred. Nevertheless, my driving style is primarily street with the occasional dirt and snow covered roads. To be honest, my wanting to lift is more form over function.
    With that said, I'm looking for insights to the best method to provide a 2" lift that will 1) be relatively safe, and 2) provide a 'leveled' appearance.
    Thanks for your patience.
    Rick
  2. Jul 1, 2010 at 5:33 AM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    Bilstien 5100's would be a good inexpensive option for you. You could also go with a spacer lift and an AAL or block in the rear (not recommended on the spacers) sisnce you have an O/R, I'd get an OME 3" kit. Are you plannng on adding any kind of aftermarket bumpers?
    Welcome to TW by the way.
  3. Jul 1, 2010 at 5:33 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    bilstein 5100s set at 1.75" in front and get a 1.5" or 2" add a leaf for the rear. get some 265/70/17 tires and you'll have yourself a good looking stance
  4. Jul 1, 2010 at 5:47 AM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    check out the pictures of my truck in my gallery. I am running this exact setup but with the fronts set to 2.5. The rims are also 17 inches. Same size tires as quoted above. Total lift cost not includind rims and tires was around $400. Should give you a good idea of what your truck would look like.
  5. Jul 1, 2010 at 6:00 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    id go with eibach springs and a set of billys.
  6. Jul 1, 2010 at 6:08 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Yup! That's what I'm looking for...minus the 17" rims (Nice setup by the way). I already have BF 276/65/16 Mud Terrains sitting in the garage from my last truck. Plan on slipping them on this fall and doing the lift as well. Sounds like I need to seriously consider the Bilstein 5100's and a leaf set up. I was kinda thinking of just going with el-cheapo spacer/blocks. Other than being able to adjust front height, what are the advantages of going Bilstein over spacers?
    Thanks
  7. Jul 1, 2010 at 6:20 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    oops, i read your name and assume you had a TRD sport with 17in wheels. :facepalm: even though your post mentioned off road, it's early...
  8. Jul 1, 2010 at 7:04 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    lol...$0.
    I'm always contentious about money spent vs. what it's used for. If i were gonna move back into 4wheeling again (had a Dodge Power Wagon years ago), I'd spend the money to really go off-roading. But that's not the case now. Honestly, married, two kids and other hobbies steer me away from that. My goal now is to at least create what I consider a good looking Taco 4x4 with some abilities to handle off road, which will primarily be work related. No bogging, sport hill-climbs, or serious trail riding.
    Currently eying the following: or Needed to add, I will be doing the work myself. My previous career was an A&P mechanic.
  9. Jul 1, 2010 at 7:13 AM
    mentose457
    mentose457 Well-Known Member
    @Reaper10
    I really like your truck setup! Just one question though, what is you gas mileage like with the lift?
    Thanks!
  10. Jul 1, 2010 at 7:28 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
  11. Jul 1, 2010 at 4:39 PM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    After some reading, I've come to see that what I am wanting is not technically a 'Body-Lift', rather a suspension lift. Because I don't want to mess with the suspension settings, I'm looking to add a 2.5" block (as opposed to an AAL) under the leaf spring and a 3" riser between the front shocks and the shock mount.
  12. Jul 1, 2010 at 6:21 PM
    Reaper10
    Brandon
    Thank for the props, Gas mileage definitely suffered a bit with the lift and bigger tires. Not too terrible I'm still able to squeak out right around 300 miles per tank. Most of my driving is all city miles too so that kinda counts against me.
  13. Jul 1, 2010 at 9:02 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    i'd advise against any blocks. i've heard nothing but bad things about them adversely affecting ride quality. go with an aal.
    case in point: http://www.tacomaworld.com/forum/technical-chat/98341-new-issue.html
  14. Jul 2, 2010 at 3:23 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    NICE find! AAL over blocks is a no-brainer now.
    Same as Eltaco, my concern then is how much more does an AAL stiffen rideability?
    Thanks for the find!
  15. Jul 2, 2010 at 5:53 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Waiting till fall before I install these and give her a 2-3" lift.
    Thoughts regarding tires and wheel options encouraged?
  16. Jul 2, 2010 at 6:03 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    an aal will stiffen the rear a little bit, but it's not bad. it fixed my back end clunking and bouncing when going over big speed bumps.
    are aware of the rear spring TSB? having the dealer perform this will replace your rear leaf springs with upgraded ones and will raise your back end up as well.
  17. Jul 2, 2010 at 6:18 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Mine does have 3 springs. I'll call today to have this corrected...Thanks.
    Any idea how much lift to be gained from this? Seems minimal.
  18. Jul 2, 2010 at 6:26 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    minimal yes, i've heard maybe 1/2" -3/4" after they settle. i didnt have it done.
  19. Jul 2, 2010 at 6:32 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    X2....that's what I put on my truck this week.
  20. Jul 2, 2010 at 6:32 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    I wonder if installing the AAL 2.5" lift would satisfy the TSB? Better yet, maybe have the dealer satisfy the extra spring with a 2.5" lift ;)
    Never hurts to ask...
