lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bso, Feb 12, 2011.
  1. Feb 12, 2011 at 7:33 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    I just picked me up a 09 tacoma my third toy love them,I need to put a 3 lift on it i looked at pro comp coil over and bilstein 5100 both in my price range,any one have anything nice to say about them.and want to add a 3 body lift dont no what brand on this one.could use some feed back thanks.
  2. Feb 12, 2011 at 7:48 PM
    chaotichoax
    chaotichoax Well-Known Member
    Jeff
    Howell, NJ
    '11 MGM DC/SB TRD Sport
    feedback = don't get a body lift
  3. Feb 12, 2011 at 11:20 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    I love this site some many smart toy owners,ok so here is my ? on the pro comp lift part # exp-k5075b do you get a true 3 inch lift and on the the bilstein f4-be5-c477-to do you get a true 2.5 lift,does any one no ???? and if you put this on do you need to lift the rear 1 inch also
  4. Feb 13, 2011 at 8:39 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Whatever the lift says, is ballpark to what you'll get.
    So if the procomp lift says 3 inches... Your gonna get +-3 inches. Same with 5100's you'll get about 2.5 inches at the 2.5 inch setting...
    Go for 5100's and eibachs.
  5. Feb 13, 2011 at 8:51 AM
    mwells32
    mwells32 Well-Known Member
    Nolanville, TX
    '09 PreRunner DC
    5100 on all four corners, fronts set to "0", OME 885 coils, Toytec 2 in AAL
    I was in the same boat as you. Looked hard at the Pro Comp lift, but it got some really poor reviews here. The shocks are what is the weak point. Those that had this lift really didnt like the ride. For about the same money you can do the 5100 with teh eibach coils and an add a leaf for the rear. Its a proven set up and one I will have installed soon. Just waiting on that tax return.
    Even with the 2.5 lift (some get more with the eibachs and 5100's set to .85) you can run 285 tires. I have researched forever here which to go with. This seams to be the one that gets the best return for your money. Next step up would be full coilovers or a spindle lift if you have a prerunner. Plus there is always the 6 inch lift if you want to go that high. I have never been a fan of body spacers on a truck. They just make things look out of wack.
  6. Feb 13, 2011 at 9:03 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    x2
  7. Feb 13, 2011 at 1:45 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    ok ,getting some great help ,I want to get this kit.but what front coils and Part # and were to get them,and how much in size of aal and were do i get that,and does any one no if the rear shocks on this kit will work if i put aal.I sure do appreciate all the help.
    Additional Images
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    Bilstein/RCD 5100 Series 2005-2011 Toyota Tacoma Pre Runner & 4WD Pre-Load Adjustable
    SKU: BE5-C477-T1 , BE5-C476-H0
    Bilstein 5100 Series Pre Load Adjustable Front shocks for a2005-2011 Toyota Tacoma 4x4 & 2wd TRD (Pre-Runner
  8. Feb 13, 2011 at 2:30 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    does any one or have you done it,if I put on the Bilstein 5100 in the front do I need to add a sway bar relocation blocks,I have seen two tacoma with them on.One had the ICON coil over,and the other had don ho coil over both were 2.5,thanks
  9. Feb 13, 2011 at 4:37 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    why would u not use the stock coils whats the pros and cons why buy new coils?? help
    if your going to run 5100 and do a need a sway bar block
  10. Feb 13, 2011 at 5:35 PM
    bso
    bso [OP] Member
    brian
    nv
    tacoma
    stock for now
    TSB what does that mean at what does the dealer have to do with it?something about rear spring?and also can some one tell me if i go with toytec 5100bil the one that come with everthing i think it 649.00 do i need the front sway bar blocks to drop it down.i have seen two taco with them on that were for sale at a dealr so no owner to ask.thanks
  11. Feb 13, 2011 at 5:58 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Throttle back alittle
    take some time to research the 1000's of thread on this web site
    as you can tell, the more you find out
    the more questions you have.
    write them down, that way you can narrow down what your goals are.
    right now your all over the map
