Lift
Discussion in 'Suspension' started by Rwood, Jun 26, 2019.
  1. Jun 26, 2019 at 5:12 AM
    Rwood
    Rwood [OP] Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    i am wondering what to do? I have a 15 TRD and it had a spacer lift on the front when I bought it to clear 285 but they still rub my UCA’s. I bought Toytec 1.5” blocks for the rear but when I installed them I got the bad vibration I guess from the driveshaft from 0-20mph and then bad around 50-60mph. I didn’t know if just buying a coil over lift, springs, UCA’s and rear shocks would work or if there is still a chance of it and if so what do I need to do? Thanks
  2. Jun 27, 2019 at 2:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Are you running factory wheels? You could change wheels and probably take of the rubbing uca. Put the Toytec carrier bearing spacer in that may help your vibration or at least make it better. My 15 is not 4wd but I went with the Toytec coilovers, jba ucas , 285/80/17 Nittos and the 2” rear block cause my truck is just a daily street driver. I also installed the carrier bearing spacer and only have a small vibration at acceleration but none at highway speeds.
