Lifted '16 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Letsgoplaces, Sep 24, 2015.
  1. Oct 18, 2016 at 11:07 PM
    #3621
    truegentlemansupplyco
    truegentlemansupplyco Active Member
    Trapper
    2017 Tacoma TRD OFF ROAD
    Did you only do the Bilstein's with stock coils or did you add coils and a AAL in the rear?
  2. Oct 18, 2016 at 11:39 PM
    #3622
    Letsgoplaces
    Letsgoplaces [OP] Well-Known Member
    Phoenix AZ
    All of them
    AAL in the rear and stay with stock could upfront.
  3. Oct 19, 2016 at 4:46 AM
    #3623
    Elp303
    Elp303 Well-Known Member
    Eric
    Maple Valley WA
    2016 TRD OR DCSB 4x4
    ADS Coilovers, Icon UCA's, ADS remote resi rear shocks, Deaver u402 stage II leafs, Demello sliders, SCS F5, Yokohama Geolandar 315/75/16
    I had to do a little trimming, and the cab mount chop. 285's will always rub. At least off road. wheels are the TRD bead locks.
    Taco_yota[QUOTED] likes this.
  4. Oct 19, 2016 at 5:12 AM
    #3624
    Wdhigh
    Wdhigh Well-Known Member
    Ridgeville, SC
    2021 Trd OR dcsb
    Hard to decide between 887 and 888. Looks great.
    end up doing new UCA's?
    Trying to decide between ome, boss and icon. Boss 2.0 out of stock and icon might be a waste for me. These ome setups look good.
  5. Oct 19, 2016 at 5:38 AM
    #3625
    OffRd 5TRMTPR
    OffRd 5TRMTPR Well-Known Member
    2016 White Tacoma TRD Off Road
    Is that a true TRD pro that you replaced the suspension with 5100's? If so....WHY?!?!?!?!
  6. Oct 19, 2016 at 5:41 AM
    #3626
    OffRd 5TRMTPR
    I did so much research between OME and BOSS it made me sick. Icon would have been a no brainier, but a waste of money for me. Neither Kit gave me the full height i desired without having to add 1" blocks. I went with 5100's and 887 coils and it is the perfect height to fit 33" tires. Rubbing less than 1% of the time (full turn hitting the bump going into my driveway).
    mmessier2 and Wdhigh[QUOTED] like this.
  7. Oct 19, 2016 at 6:59 AM
    #3627
    Letsgoplaces
    Phoenix AZ
    All of them
    Haha no never would I do that bro. That fox setup on the pro is legit.
  8. Oct 19, 2016 at 7:21 AM
    #3628
    Normagene
    Normagene MUTANT TACO
    New England
    Appreciate some advice.
    I was thinking of gett'n a leveling kit, cost around $525 locally, checked with two local shops.
    Or should I go with 5100s?
    I know there's a big price increase, but I'm thinking the ride with a leveling kit will be much harder.
    I WILL NOT BE OFF ROADING THE TRUCK
    This is strictly for looks, and a smoother/safe ride.
    Not look'n for a Huge Lift, maybe 2-2.5 front and 1" rear.
    I will have BFG K02s 265/70R17s
    So......if I end up going with 5100 kit, what kit would be best? (I looked at their site and they have a range of kits, depending if u go all around or spacers/blocks in the rear, I don't know what's best)
    Also what would the kit cost? I know the biggest expense is the install labor.
    Thanks
    Norma
  9. Oct 19, 2016 at 7:48 AM
    #3629
    Trapper
    im installing my 5100s tomorrow what block did you use?
  10. Oct 19, 2016 at 7:51 AM
    #3630
    Trapper
    go to www.headstrongoffroad.com they will get you the best deal and are extremely knowledgable. id do the 5100's all around with a AAL in the rear and a OME coil up front but since you are only going to be on the road a spacer leveling kit like the one you said is 525 will be more than sufficient. what brand is it.
  11. Oct 19, 2016 at 8:45 AM
    #3631
    Normagene
    New England
    ReadyLift is what both shops said they use. One shop called them because they did have an issue with those on the OR models. Think he said driveshaft vibration.
    I'll checkout the link you posted
    So you think a leveling kit is sufficient. What about ride quality?
    Thanks
  12. Oct 19, 2016 at 8:56 AM
    #3632
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    no skid plate, no rigid fogs, no badge and it looks like it's inferno. Why would you think it's a Pro?
  13. Oct 19, 2016 at 9:52 AM
    #3633
    OffRd 5TRMTPR
    Didn't have to use any blocks since I went with the 5100 kit from headstrong. The OME and Toytec Boss are only a 2" lift and you can achieve 3" by adding a block. This is not something I wanted to mess with so I went with the 5100's and 887 coils with AAL. Saved me a few hundred dollars in the end and am happy with the results.
  14. Oct 19, 2016 at 12:23 PM
    #3634
    Trapper
    nice i ordered from there as well. I did the 888 i hope i made the right choice. ill post pictures in a few days.
  15. Oct 19, 2016 at 1:39 PM
    #3635
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Are you going with AAL in the rear or the Dakars? I want to do the 888's with Dakars to fit 285/75/16. Are you going to measure pre and post lift?
  16. Oct 19, 2016 at 1:41 PM
    #3636
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    What setting do you have your 5100s at with the 887 coils and how much lift did you get over stock?
  17. Oct 19, 2016 at 2:11 PM
    #3637
    quis23
    quis23 Well-Known Member
    Duan
    good ole' Manassas VA
    Still using the stock UCAs. Got the alignment in acceptable specs. It rides fine. I will be upgrading UCAs soon though for a lil' more adjustment.
  18. Oct 19, 2016 at 2:56 PM
    #3638
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    What size tires?
    61ragtop likes this.
  19. Oct 19, 2016 at 2:58 PM
    #3639
    Trapper
    I ended up doing just an AAL yes i will measure before and after.
    Age315[QUOTED] likes this.
  20. Oct 19, 2016 at 3:10 PM
    #3640
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    It's not. Look at the headlights and fogs. Also, he was referring to the PRO grille when he said "..finally got these in..." and possibly the 5100's as well.
